1/4" x 50ft Synthetic Winch Rope 7,400 lbs Breaking Strength
This is the installation process for the TH-0023: 1/4" x 50ft Synthetic Winch Rope 7,400 lbs Breaking Strength, for your reference during the installation process.
Maintenance & Safety Tips
Avoid Sharp Edges: Never allow the synthetic rope to rub against sharp rocks or rusted metal edges.
Keep Clean: Rinse the rope with fresh water after mud or sand exposure to prevent internal fiber abrasion.
Inspection: Regularly check for fraying, melted fibers, or significant discoloration. Replace the rope if the core is damaged.
Switch your winch to "Free Spool" mode and remove the old line.Inspect the drum for any burrs or sharp edges.
node: Smooth out any sharp spots with sandpaper to prevent cutting the synthetic fibers.
Feed the terminal end (without the hook) through the fairlead and onto the winch drum.
Secure the rope end using the drum’s specific attachment bolt or plate. Ensure the Protective Sleeve is positioned at the start of the wrap on the drum.
Re-engage the winch clutch.
Have an assistant apply slight tension to the rope while you spool it in. Ensure the rope wraps tightly and neatly across the drum.
Note: At least 5-6 wraps must remain on the drum to provide full holding power.
When about 2 feet of rope remains, slide the Rubber Winch Stopper onto the rope (through the thimble end).
Position it between the hook and the fairlead.
Remove the clevis pin from the hook.
Place the stainless steel thimble into the hook opening, re-insert the pin, and secure it with the cotter pin.
Slow-spool the winch until the Rubber Winch Stopper is snug against the fairlead.
