This is the installation process for the ER-0355: 2007.5-2009 6.7L Ram Cummins Tuner Harness Plugs,provided for your reference during installation.
This kit is specifically designed for 2007.5-2009 6.7L Ram Cummins diesel vehicles. Following the tuning and physical removal of the EGR and DPF systems, numerous unused factory wiring connectors remain within the vehicle's chassis and engine bay.
1, 2 | EGR Motor Plugs | Top of Engine / EGR Valve Area | Insert into the two disconnected EGR motor connectors on top of the engine. |
3, 4 | Throttle Body & EGR Actuator Plugs | Intake Horn / Throttle Body | Insert into the throttle control and EGR actuator connectors near the intake. |
5 | EGR Temperature Sensor Plug | Intake Manifold / Rear of Engine | Protects the electrical connector for the EGR temperature sensor. |
6, 12 | NOx Sensor Plugs | Chassis / Near Exhaust System | Insert into the connectors for the NOx sensors located along the frame rail. |
7 | EGT Sensor Plug (Front) | Exhaust System (Former DPF/CAT) | Insert into the first Exhaust Gas Temperature (EGT) sensor connector. |
8, 9, 10 | EGT Sensor Plugs (Mid/Rear) | Exhaust System (Former DPF/CAT) | Insert into the remaining three EGT sensor connectors under the chassis. |
11 | Pressure Sensor Plug | Under Chassis / Frame Rail | Insert into the original DPF Pressure (Differential) sensor wiring harness. |
