This is the installation process for the ER-0334: 2008-2010 6.4L Ford EGT Exhaust Temperature Sensor 8C3Z5J213D,provided for your reference during installation.
Locate the exhaust assembly on the passenger side of the vehicle. Follow the exhaust pipe rearward; the component is situated at either the inlet or the outlet of the DPF canister.
At least 30 minutes before removal, spray a generous amount of penetrating lubricant onto the threads of the old sensor. For heavily corroded exhaust pipes, it is recommended to apply lubricant multiple times the day before removal.
Locate the sensor's electrical connector. Depress the locking tab and disconnect the plug. Exercise caution to avoid pulling forcefully on the wiring harness, as this may damage the corresponding socket on the vehicle side.
Use a 13mm wrench to loosen the sensor by turning it counter-clockwise. If the sensor is seized by rust and cannot be turned, try gently tightening it slightly first before attempting to loosen it; alternatively, use a torch to apply localized heat to the mounting boss on the exhaust pipe.
Apply a small amount of high-temperature anti-seize compound to the threads of the new sensor. Crucially, ensure that the anti-seize compound does not come into contact with the sensor's probe tip, as this will result in inaccurate readings.
Thread the new sensor into the exhaust pipe boss by hand. Hand-threading first ensures proper thread alignment and prevents cross-threading. Use a 13mm wrench to tighten the sensor. Do not overtighten,as this may make future replacements difficult or cause the mounting boss to crack.
Plug the sensor connector into the vehicle-side socket, ensuring you hear an audible "click" to confirm it has locked securely. Verify that the wiring harness is routed clear of any moving parts or sources of extreme heat.
