2008-2010 6.4L Ford F250 F350 Cold Air Intake
This is the installation process for the IA-0006: 2008-2010 6.4L Ford F250 F350 Cold Air Intake,provided for your reference during installation.
Park the vehicle on a level surface and allow the engine to cool down. Disconnect the negative terminal of the battery.
Locate the filter status monitor above the air filter housing. Carefully disconnect and remove it. Store it properly for future use.
Press the harness clips and carefully unplug the MAF (Main Air Flow) sensor connector.
Using a screwdriver or socket wrench, loosen the metal clamp connecting the intake hose to the air filter box and gently detach the hose from the air filter box connector.Using both hands, steadily lift the entire original air filter box assembly upwards and remove it from the engine compartment.
Remove the MAF sensor from the original box and install it onto the new cold air intake.​
Install the filter onto the new cold air manifold and tighten the metal clamp.
Connect the new cold air intake pipe to the original intake hose and tighten the clamp. Secure the new cold air intake pipe firmly at the bottom using the provided bracket.
Reconnect the MAF sensor harness and install the air filter monitor.
After confirming that the installation is correct, reconnect the battery, start the engine, and check for any air leaks or unusual noises.​
