2008-2010 6.4L Ford Powerstroke Diesel Air Filter Replaces FA1886
This is the installation process for the FI-F-10-03: 2008-2010 6.4L Ford Powerstroke Diesel Air Filter Replaces FA1886,provided for your reference during installation.
Loosen all the metal spring clips on the top of the air filter box, then smoothly remove and lift the upper cover of the air filter box.
Pull out the old cylindrical air filter directly. Before installation, compare the old and new filters side by side to ensure they are identical in size and appearance.
Smoothly push the new air filter into place along the tracks inside the box.
Reassemble the upper cover of the air filter box, snap it back on, and securely tighten all the metal spring clips.
