This is the installation process for the ER-0306: 2008-2010 6.4L Ford Powerstroke Fuel Temp SOTF Switch,provided for your reference during installation.
First, open the truck hood. It is recommended to disconnect the negative terminals of both power sources.
Locate the fuel temperature sensor and disconnect it from the wiring harness.
Cut a small notch in the rubber gasket on the left side of the driver's side step in the cab. Be careful not to damage any wires in the wiring harness.
Use a steel wire or iron wire to pass through the firewall, through the rubber gasket, and secure one end of the switch wire to the steel wire or iron wire with tape. Pull the switch wire into the engine compartment.
Pull the switch wire correctly to the sensor location and wrap the switch wire with the flexible tubing provided in the kit.
Assemble the provided connector and install the switch wiring harness onto the connector, ensuring it is properly installed. Polarity is not important.
Insert the new switch connector into the fuel temperature sensor wiring harness, and then wrap another original sensor with tape to prevent corrosion.
Drill a hole in the appropriate location and install the switch. The specific location may vary depending on the truck model and individual operating habits.
After installing the switch, bundle and organize the switch wiring harness and other wiring harnesses under the dashboard.
2008-2010 6.4L Ford F250 F350 F450 F550 Powerstroke 4inch Cat & DPF Delete Pipe
2008-2010 6.4L Ford Powerstroke Coolant Filtration System & Filter Kit
2008-2010 Ford 6.4L Powerstroke 5" Dp-Back DPF Delete Pipe(With Muffler)
2008-2010 Ford 6.4L Powerstroke 5" Downpipe Back DPF Delete Pipe
2008-2010 6.4L Ford F250 F350 Cold Air Intake
