This is the installation process for the ER-0319: 2008-2010 6.4L Ford Powerstroke Tuner Harness Plug Kit,provided for your reference during installation.
This kit is specifically designed for 2008-2010 6.4L Ford Powerstroke diesel vehicles. Following the tuning and physical removal of the EGR and DPF systems, numerous unused factory wiring connectors remain within the vehicle's chassis and engine bay.
1 | EGR Motor Plug | Engine Bay / Near EGR Valve | Insert into the disconnected EGR stepper motor wiring harness. |
2 | Throttle Body Plug | Intake Air Horn / Intake Pipe | Insert into the disconnected throttle body (butterfly valve) harness. |
3 | EGT / EGR Temp Plug | Engine Bay / Exhaust Manifold | Protects the electrical connector for the EGR temperature sensor. |
4 | EGR Actuator Plug | Engine Bay / EGR System | Seals the disconnected EGR control actuator connector. |
5, 6, 7 | EGT Sensor Plugs | Exhaust System (Former DPF/CAT Location) | Insert into the three disconnected Exhaust Gas Temperature (EGT) sensor connectors under the chassis. |
8 | Pressure Sensor Plug | Under Chassis / Near Frame Rail | Insert into the original DPF Backpressure Sensor wiring harness. |
