2011-2016 6.6L Chevy Silverado Sierra EGT Exhaust Temperature Sensor 19418987
This is the installation process for the ER-0348: 2011-2016 6.6L Chevy Silverado Sierra EGT Exhaust Temperature Sensor 19418987,provided for your reference during installation.
Locate the exhaust assembly on the passenger side of the vehicle. Follow the exhaust pipe backwards; this component is located at the DOC inlet.
First, At least 30 minutes before removal, spray a generous amount of penetrating lubricant onto the threads of the old sensor. For severely corroded exhaust pipes, it is recommended to apply lubricant multiple times the day before removal.
Loosen the sensor by turning it counterclockwise with a wrench. If the sensor is stuck due to rust, try tightening it gently first, then try to loosen it; alternatively, use a blowtorch to locally heat the mounting boss on the exhaust pipe.​
