2011-2016 6.6L Chevy Silverado Sierra EGT Exhaust Temperature Sensor 273-10029
This is the installation process for the ER-0349: 2011-2016 6.6L Chevy Silverado Sierra EGT Exhaust Temperature Sensor 273-10029,provided for your reference during installation.
Locate the exhaust assembly on the passenger side of the vehicle. Follow the exhaust pipe backwards; this component is located at the DOC outlet.
First, At least 30 minutes before removal, spray a generous amount of penetrating lubricant onto the threads of the old sensor. For severely corroded exhaust pipes, it is recommended to apply lubricant multiple times the day before removal.
Locate the sensor's electrical connector. Press down the locking latch and unplug the connector. Handle with care, avoiding pulling on the wiring harness, as this may damage the corresponding socket on the vehicle side.
Use a wrench to loosen the sensor by turning it counterclockwise. If the sensor is stuck due to rust, try tightening it gently first, then try loosening it; alternatively, use a blowtorch to locally heat the mounting boss on the exhaust pipe.​
Apply a small amount of high-temperature anti-seize agent to the threads of the new sensor. Make sure the anti-seize agent does not come into contact with the sensor's probe tip, as this will cause inaccurate readings.
Screw the new sensor into the exhaust pipe connector by hand. Tightening by hand first ensures thread alignment and prevents mis-threading. Use a screwdriver to tighten the sensor. Do not overtighten, as this may make future replacement difficult or cause the mounting connector to crack.
