This is the installation process for the ER-0337: 2011-2023 6.7L Ford EGT Exhaust Temperature Sensor BC3Z-12B591-B,provided for your reference during installation.
The sensor is typically mounted on the metal cross-pipe connecting the exhaust manifold and EGR cooler under the hood, or other suitable original equipment replacement location.
Press the safety latch on the sensor harness connector and gently pull it off. Handle with care to avoid pulling the harness, as this may damage the corresponding socket on the vehicle side.
Use a wrench to loosen the sensor by turning it counterclockwise. If the sensor is stuck due to rust, try gently tightening it first, then try loosening it to remove the old sensor.
Apply a small amount of high-temperature anti-seize compound to the threads of the new sensor. Ensure the anti-seize compound does not come into contact with the sensor probe tip, as this will cause inaccurate readings.
Hand-tighten the new sensor into the exhaust pipe boss. Hand-tightening first ensures thread alignment and prevents mis-threading. Tighten the sensor using a wrench. Do not overtighten, as this may make future replacement difficult or cause the mounting boss to crack.
Insert the sensor connector into the socket on the vehicle side, ensuring you hear a click to confirm it is securely locked. Check that the wiring harness is away from any moving parts or sources of heat.
