This is the installation process for the ER-0343: 2013-2018 6.7L Dodge Ram EGT Exhaust Temperature Sensor 68085774AB,provided for your reference during installation.
Locate the exhaust assembly on the passenger side of the vehicle. Follow the exhaust pipe backwards; this component is located before the DOC, after the DOC, after the DPF, and after the SCR.
At least 30 minutes before removal, spray a generous amount of penetrating lubricant onto the threads of the old sensor. For severely corroded exhaust pipes, it is recommended to apply lubricant multiple times the day before removal.
Loosen the sensor by turning it counterclockwise with a wrench. If the sensor is stuck due to rust, tighten it gently first before attempting to loosen it; alternatively, use a blowtorch to locally heat the mounting boss on the exhaust pipe.
Screw the new sensor into the exhaust pipe connector by hand. First, tighten by hand, ensuring the threads are aligned, but avoid overtightening. Then, tighten the sensor with a screwdriver. Do not overtighten, as this may make future replacement difficult or cause the mounting connector to crack.
