2015-2025 6.7L Ford EGT Exhaust Temperature Sensor FC3Z-12B591-A
This is the installation process for the ER-0338: 2015-2025 6.7L Ford EGT Exhaust Temperature Sensor FC3Z-12B591-A,provided for your reference during installation.
Locate the exhaust assembly on the passenger side of the vehicle. Follow the exhaust pipe backwards; this part is located at the DOC inlet after the turbocharger.
First, disconnect the vehicle's power supply. At least 30 minutes before removal, spray a penetrating lubricant on the threads of the old sensor. For severely corroded exhaust pipes, it is recommended to apply lubricant multiple times the day before removal.
Use a 13mm wrench to loosen the sensor by turning it counterclockwise. If the sensor is stuck due to rust, try gently tightening it first, then try loosening it. Alternatively, use a blowtorch to locally heat the mounting boss on the exhaust pipe.
Apply a small amount of high-temperature anti-seize agent to the threads of the new sensor. Make sure the anti-seize agent does not come into contact with the sensor's probe tip, otherwise it will cause inaccurate readings.​
Screw the new sensor into the exhaust manifold boss by hand. Tightening by hand first ensures thread alignment and prevents mis-threading. Tighten the sensor using a 13mm wrench. Do not overtighten, as this may make future replacement difficult or cause the mounting boss to crack.​
Insert the sensor connector into the socket on the vehicle side, ensuring you hear a click to confirm it is securely locked. Check that the wiring harness is away from any moving parts or sources of heat.
