ColdFoundry
I'm monitoring my 2006 6.0L with an Edge Insight. Cruising at 65mph, my Coolant Temp (ECT) is 192°F, but my Oil Temp (EOT) is hitting 210°F. That’s an 18-degree delta. HOW close am I to a catastrophic failure? I’ve heard 15 degrees is the limit before the oil cooler is considered "clogged." Should I try a chemical flush (like VC-9) first, or is it a waste of time once the delta stays this high?
