What’s up, Cummins crew. We spend a lot of time and money on the big-ticket items for our trucks—turbo upgrades, tunes, exhausts, suspension. But often, it’s the smaller, unsung wiring components that make or break a clean, functional, and reliable build. Having the right harness or cable can mean the difference between a weekend install turning into a multi-day wiring nightmare and a seamless “plug-and-play” experience.
Today, let’s talk about a few of these critical supporting actors. Whether you’re chasing accurate data, simplifying your tuning interface, or just trying to get your diagnostic tools to talk to your newer truck, the right wiring upgrade is key. We’ll cover four specific parts from TruckTok that address very common, but often overlooked, hurdles for 2007.5-2024 6.7L Ram owners.
The Solution: This isn’t about tricking the computer; it’s about giving it better data. The TruckTok IAT Sensor Extension Harness is a simple yet brilliant fix. It’s a high-quality extension cable made with high-temperature resistant materials, meaning it won’t degrade even in our harsh engine bays.
The Application & Benefit: This harness allows you to easily relocate your IAT sensor to a cooler location. A popular spot is the intake pipe closer to the intercooler outlet, where it can read the actual temperature of the charge air after it has been cooled. This provides your ECU (and your tuner, if you’re data-logging) with a much more accurate reading. The result? The ECU can run more optimal timing, potentially unlocking power and consistency that was being left on the table. The installation is dead simple—unplug the factory sensor, plug this harness in between the sensor and the factory connector, and mount the sensor in its new, cooler home. It’s a must-have for any truck running higher horsepower or towing heavy in hot climates. Check out this simple problem-solver for all 2007.5-2024 Rams right here.
The Solution: The TruckTok SOTF (Switch-On-The-Fly) Switch is designed specifically for this. It’s a clean, simple switch that interfaces with your truck’s existing wiring.
The Application & Benefit: This switch is designed to work seamlessly with EZ-Lynk devices. Using appropriate high-temperature rated wire, it connects to your truck’s CCV (Controller Area Network or “C-CAN”) bus—the vehicle’s internal communication network. Once installed and configured in your EZ-Lynk app, it allows you to scroll through your preset tuning files with the simple turn of a dial or press of a button, all without ever touching your phone. The installation is clean and doesn’t require splicing into major power wires. It’s the professional way to add instant, dashboard-accessible control over your tuning, making it easy to adapt to changing conditions (entering a highway, starting a long climb, hitting city traffic) safely. If you run an EZ-Lynk on your 2010+ Cummins, you can find this game-changing accessory at this link.
The Universal Problem It Creates:
While excellent for theft prevention, this module becomes a significant roadblock for legitimate and essential tasks that enthusiasts and owners need to perform:
Summary & Choosing the Right One:
In summary, while they might not be as flashy as a new turbo, these wiring components are foundational to a modern, well-executed Cummins build. They solve real-world problems that stand between you and your truck’s full potential, whether it’s more accurate engine management, convenient control, or simply being able to apply the tune you paid for. Investing in quality here prevents headaches and ensures everything else in your mod list works as intended.
Disclaimer: Always ensure any modifications, especially those related to tuning and vehicle electronics, comply with local, state, and federal regulations in your area. Some modifications may impact emissions compliance or vehicle warranties.
1. The Intake Air Temperature (IAT) Sensor Extension Harness: For Accurate, Cool Data
The Problem: On a heavily worked or modified 6.7L, under-hood temperatures can get extreme. The factory Intake Air Temperature (IAT) sensor is mounted on the intake horn, right above the hot engine. After a hard pull or in traffic, radiant heat from the engine valley and hot air from the radiator can soak into this area. This causes the sensor to read artificially high intake air temps. Since your ECU uses this data to adjust timing and fueling, inaccurate IAT readings can lead to overly conservative (pulled) timing, effectively robbing you of power and efficiency even when the air actually entering the cylinders is much cooler.The Solution: This isn’t about tricking the computer; it’s about giving it better data. The TruckTok IAT Sensor Extension Harness is a simple yet brilliant fix. It’s a high-quality extension cable made with high-temperature resistant materials, meaning it won’t degrade even in our harsh engine bays.
2. The EZ-Lynk / CCV SOTF Switch: Tune Control at Your Fingertips
The Problem: You’ve got an EZ-Lynk AutoAgent with multiple custom tunes—maybe a high-performance street tune, a tow tune, and an eco tune. Switching between them typically requires pulling out your phone, opening the app, and going through several taps. Not exactly safe or convenient while driving. You want a physical, tactile switch.The Solution: The TruckTok SOTF (Switch-On-The-Fly) Switch is designed specifically for this. It’s a clean, simple switch that interfaces with your truck’s existing wiring.
3. Security Gateway Bypass Cables: Unlocking Your 2018+ Cummins’ Potential
Starting with the 2018 model year, Ram introduced a critical piece of security hardware: the Security Gateway Module (SGM). Think of it as a vigilant security checkpoint sitting directly between your OBD-II port and the truck’s vital internal networks (like the CAN buses). Its primary function is to monitor all communication attempts and block any it deems unauthorized or potentially unsafe for the vehicle's controllers.The Universal Problem It Creates:
- Performance Tuning: Flashing a new engine calibration file with tools like EFILive is typically blocked.
- Advanced Diagnostics: Many professional-grade scan tools cannot perform deep-level diagnostics or module programming.
- Simple Adjustments: Basic tasks like correcting your speedometer for new tire sizes (using EZ Lynk or other programmers) become impossible.
- Aftermarket Accessories: Programming or integrating certain accessories (like AMP Research power steps) may require direct module communication.
- Module Recovery: In rare cases where the security module itself fails, tools like MM3 need direct access to recover the system.
The Standard & Essential Solution: TruckTok Bypass Cable
For the vast majority of owners who need reliable, occasional access for tuning or diagnostics, the standard TruckTok 2018-2024 6.7L Bypass Cable is the go-to choice.- Core Function: It is specifically designed to bypass the Security Gateway Module, creating a direct and unobstructed communication path from your OBD-II port to the truck’s network. After installation, your OBD-II port continues to work normally for all standard functions.
- Primary Use Case: Its description is very clear: “If you use EFI Live, you need it to flash Tune into your 6.7L engine.” This is its fundamental purpose.
- Critical Installation Note – YEAR MATTERS!:This cable highlights a vital technical difference between model years. The wiring pinout changed, and following the correct instruction is mandatory for it to work:
- For 2018 models: Replace yellow with blue and green with brown.
- For 2019+ models: Replace yellow with brown and green with blue.
The Heavy-Duty & Versatile Specialist: TruckTok HD Security Gate Bypass Cable
For users who demand maximum durability, use the cable more frequently, or have a broader range of communication needs, the TruckTok 2018+ RAM Cummins HD Security Gate Bypass Cable is the upgraded choice.- Enhanced Construction: As the “HD” (Heavy-Duty) name implies, it is built with even more durable, impact-resistant, and heat-resistant materials. This suggests a tougher jacket, more robust connectors, and potentially a higher gauge wire, making it ideal for shop environments, frequent use, or harsh installation conditions.
- Broader Application Scope: While it performs the core bypass function, its description emphasizes versatility: “This cable is suitable for various platforms.”It explicitly lists a wider array of uses beyond just EFILive tuning:
- Connecting with a diagnostic code reader.
- Flashing a tune with EFILive.
- Changing tire size with EZ Lynk.
- MM3 applications if your security module fails.
- Programming AMP Research side steps.
- Same User-Friendly Principle: Like the standard version, it allows the OBD-II port to retain OEM function and is designed as a reusable cable, not requiring permanent modification to the truck.
- Choose the Standard Bypass Cable if your primary need is flashing tunes with EFILive and performing occasional diagnostic/tire size changes. It's the cost-effective, essential tool for most tuners.
- Choose the HD Bypass Cable if you are a professional, frequent user, operate in extreme environments, or require its noted compatibility with a wider range of specific platforms and accessories like MM3 or AMP steps. The investment is in enhanced durability and stated multi-platform versatility.
