AirBagged_02
Every early 6.7L Cummins owner dreads the P2262 code when the VGT sliding nozzle gets completely choked out by heavy soot. Replacing the Holset HE351VE turbo is an expensive band-aid if you don’t fix the underlying root cause. We all know that blocking off the soot circuit keeps the exhaust stream pure, but what are you guys doing to actually clean out or protect a sticky nozzle without pulling the heavy turbo apart? Are high-temp exhaust flushes or heavy towing under load enough to sweep the veins clean?
What worked for your 2007-2012 rig?
