Differentiating between a minor leak and a blown head gasket is every 6.7L Cummins owner’s nightmare. What specific symptoms made you realize your cooling system pressure wasn't just a faulty radiator cap?
If you’ve dealt with the dreaded "overflow puke," how did you confirm the failure—was it a combustion leak test, or did the upper radiator hose stay rock-hard overnight? Many wonder if upgrading to head studs is enough to prevent a repeat, but what has your experience been with the early 6.7L gaskets under high boost?
