How can you tell the difference between a failing EGR cooler and a blown head gasket before you start tearing the top end apart?
BasementBuilt
I’m seeing white smoke and losing coolant, but my 6.0L isn't overheating yet. What are the definitive tests you guys use to distinguish a ruptured EGR cooler from the dreaded blown head gaskets? I’m trying to avoid a full cab-off teardown if it’s just the cooler.
How many of you have had success with a pressure test on the degas bottle, and what pressure readings should I look for to confirm it's the gaskets lifting? Also, if I park nose-down and find coolant in the intake, is that a "smoking gun" for the EGR?
For the head gasket check, the pressure test on the degas bottle is the industry standard. Get a pressure gauge and tee it into the small line going to the degas bottle. Drive the truck and get it up to operating temp, then do a few heavy wide-open throttle (WOT) pulls. If the pressure climbs rapidly and exceeds 15-16 PSI, or if it vents out of the cap under heavy load, your head gaskets are lifting. A failing EGR cooler can cause white smoke and coolant loss, but it won't typically 'pump' the cooling system up to those high pressures as fast as combustion gases from a blown gasket will.
