How critical is a "head stud" upgrade for a daily-driven LBZ if you’re only running a +100HP tune, or is the factory clamping force enough?
HeavyMilled
I’m running a +100HP tune on my daily LBZ and wondering: What is the real-world limit for factory head bolts before they start to stretch?
How many of you are pushing 500+ HP on stock clamping force without issues? Is it worth the "peace of mind" to install ARP studs now, or is the LBZ head gasket tough enough for moderate street tuning? I want to avoid a blown gasket, but I’d love to hear your experiences before I tear it down. What's your setup?
The debate between factory TTY bolts and ARP studs on an LBZ is all about cylinder pressure. While the LBZ head gaskets are robust, a +100HP tune can push boost levels to where the factory bolts begin to stretch, especially during heavy towing or high-load pulls.
What is the magic number? Most experts agree that 500-550 HP is the "danger zone." How many of you have pushed past that on stock bolts? If you plan on adding a bigger turbo or high-flow injectors later, doing studs now is a smart "peace of mind" investment. However, if you’re staying at a moderate street tune, the factory clamping force often holds up fine—provided your cooling system is healthy.
