RustBelt_02
We all love the 2004.5–2005 LLY torque, but the factory head gaskets are a notorious ticking time bomb. Once they pop, everyone has a different recipe for the "permanent" cure. Some guys claim throwing in standard Grade C gaskets with ARP studs does the trick, while others swear you have to machine the heads, drop in fire rings, and upgrade to the LBZ-style mouthpiece and water pump to kill the overheating issue at the source.
If you’ve been down this road, what actually worked for you? Did studs alone save your engine, or did you have to overhaul the whole cooling system?
