How do you tell if your oil leak is just a simple vacuum pump gasket or the dreaded upper pan failure, and what sealant actually holds up long-term?
ProperFit
Chasing oil leaks down the back of a 6.7L Powerstroke can drive anyone crazy. What specific diagnostic tricks did you use to confirm your leak was just a simple, cheap vacuum pump gasket rather than the dreaded upper oil pan failure?
If you had to tackle that brutal upper pan job, how did you pre-clean the block to ensure a perfect bond, and what sealant actually holds up long-term—did you swear by something else? I want to know what your experience has been, how long your fix has lasted?
Don’t guess and don't rely on a flashlight alone. The absolute best trick is to use a fluorescent UV oil dye kit. Clean the back of the engine completely with brake cleaner, dump the dye into your oil, and drive it for 20 minutes. Inspect it at night with a UV light.
If the dye trail starts above the oil pan rail, right behind the belt tensioner on the passenger side, it’s your vacuum pump gasket (a $15 fix). Also, use a telescoping inspection mirror to look at the vacuum pump's bottom bolt. If that bolt head is wet, the pump is leaking. If the pump area is dry but the RTV seal along the upper pan rail is weeping all the way around the back corners, you just won't escape the upper pan nightmare.
Chasing leaks on the 6.7L is a nightmare, but here is the classic trick to save your sanity: use a mirror or borescope to look right behind the high-pressure fuel pump gear housing. If the valley is bone dry but the passenger-side front and bellhousing are soaked, it's usually just the vacuum pump gasket bleeding down. If the leak originates strictly below the crossover tube and mirrors the upper pan seam, you’re in for the big job.
If it is the upper pan, the secret to a permanent bond isn't just the sealant—it's the prep. You have to let the block drain overnight, brake-clean it till it’s surgically clean, and then scuff the mating surface with a Scotch-Brite pad so the silicone can actually bite.
Don't bother with cheap generic RTV. Use Motorcraft TA-31 or TA-357 (the grey high-torque stuff) or Permatex Right Stuff Black. Let it skin over, torque it to spec, and let it cure for a full 24 hours before adding oil. Mine has been bone dry for 50k miles.
