BustedPlug_01
Every 2013-2018 6.7L Cummins owner knows the frustration of dead-stop turbo lag, but few realize the factory intake throttle valve is actively choking their VGT. By creating an artificial restriction to force EGR flow, that stock butterfly valve destroys intake velocity. When you slap on a high-flow delete spool, you dramatically increase air volume—but how exactly does that extra intake air translate into near-instantaneous exhaust drive pressure to spool the VGT turbine faster? Is it purely fluid dynamics, or does the cleaner, soot-free combustion burn hotter and expand more rapidly?
What’s your experience? Did dropping the throttle valve completely eliminate your off-the-line lag, or did you need a custom tune to actually feel the difference in your spool times?
