The 2011-2023 6.7L Powerstroke represents the pinnacle of Ford's diesel engineering. With its compacted graphite iron block, reverse-flow cylinder head, and advanced fuel system, this engine has proven itself capable of exceptional power, reliability, and longevity. But even the most robust diesel architecture must contend with one unavoidable physical reality: crankcase pressure and the oil vapor it carries.
The factory Closed Crankcase Ventilation system on the 6.7L is designed to manage this pressure while meeting emissions requirements. But like all factory CCV systems, it represents a compromise—one that introduces oil contamination into the intake tract, gradually degrades intercooler efficiency, and can ultimately affect combustion quality.
Understanding why the 6.7L's CCV system deserves attention requires examining the engineering principles at work, the consequences of oil ingestion, and how a thoughtfully designed solution can address these issues at their source.
The factory solution: The 6.7L's CCV system routes these gases through a series of baffles and a separator built into the valve cover. The goal is to capture larger oil droplets and return them to the crankcase while allowing the remaining gases to be drawn into the intake system and reburned.
The limitation: No passive separator is 100 percent efficient. A portion of the oil vapor inevitably passes through the baffles and enters the intake stream. This oil-laden air travels through the turbocharger compressor, through the intercooler, through the charge air piping, and eventually into the combustion chambers.
The cumulative effect: Over tens of thousands of miles, this continuous oil mist creates a measurable performance degradation that owners often mistake for normal engine aging.
Why this matters: The strength of this vacuum varies with engine load and RPM. At high boost, the intake pressure is actually positive, which means the CCV system must rely on pressure differentials within the crankcase itself to evacuate gases. This varying flow rate affects how much oil vapor is carried into the intake at different operating conditions.
The consequence: At idle and light load, when intake vacuum is highest, the CCV system pulls maximum flow from the crankcase—precisely when the engine is least able to tolerate intake contamination. This is why oil residue often accumulates most noticeably in the intake tract during prolonged idling or light-load operation.
Turbocharger Compressor Wheel Fouling
The turbocharger compressor wheel spins at speeds exceeding 100,000 RPM. It is a precision aerodynamic component balanced to microscopic tolerances. When oil mist passes over the wheel, a thin film deposits on the blades. This film attracts particulate matter, creating an uneven surface over time.
The effect: Compressor efficiency degrades. The wheel cannot accelerate air as effectively, leading to slower spool times and reduced peak boost potential. This is not a sudden failure but a gradual erosion of performance.
Intercooler Contamination (The Hidden Efficiency Killer)
The intercooler's function is to transfer heat from compressed air to the ambient air passing over its core. Oil acts as an insulator. When the internal surfaces of the intercooler become coated with oil, they lose their ability to transfer heat efficiently.
The quantifiable result: Higher Intake Air Temperatures. Hotter air is less dense, which reduces the available oxygen for combustion. The ECM compensates by adjusting fuel delivery, but the fundamental efficiency loss remains. An oil-fouled intercooler is a compromised intercooler regardless of its core size.
Charge Air Boot Degradation
The silicone and rubber boots connecting the intercooler pipes are designed to handle pressure and heat—but not continuous oil exposure. Over time, oil breaks down these materials, causing softening, expansion under boost, and eventual cracking or blow-off.
Intake Manifold and Valve Deposits
The oil vapor eventually reaches the intake manifold and valves, where it mixes with the smallest amount of EGR soot (if present) and deposits as a sticky varnish. This varnish accumulates on manifold walls and, critically, on intake valve stems and heads.
The 6.7L-specific factor: As a direct-injection engine, the 6.7L has no fuel washing over the intake valves to clean these deposits. Any oil that reaches the valves stays there, gradually reducing flow area and disrupting the carefully engineered intake port geometry.
How traditional catch cans work: An external canister is installed in the CCV line between the valve cover and the intake. As oil-laden vapor passes through the can, it encounters baffles, mesh, or other media that cause oil droplets to coalesce and collect in a reservoir. The cleaned air continues to the intake. The drawback is maintenance—the reservoir must be emptied periodically, and if forgotten, the can becomes a restriction.
The Internal Catch Can concept: Instead of an external can, the ICC is integrated into the existing valve cover structure. It utilizes the void space within the valve cover itself as a separation chamber. A precisely machined notch in the internal baffle allows separated oil to drain back into the crankcase when the engine is off and pressure equalizes.
The engineering advantage: This design requires no external mounting, no additional hoses, no periodic draining, and no maintenance. It operates passively, using the existing valve cover volume to achieve oil separation.
Why pressure drop matters: The CCV system relies on pressure differential to evacuate crankcase gases. If a separation device creates excessive restriction, crankcase pressure can rise, leading to oil seal leaks, gasket failures, and increased blow-by.
The Venturi principle in action: By shaping the internal passages to create controlled acceleration and deceleration of the vapor stream, the ICC can promote oil droplet coalescence without creating significant flow restriction. This allows effective separation while maintaining the pressure differentials necessary for proper crankcase evacuation.
The "no angles" design: The product mentions "streamline routing with no angles." This is significant because every sharp turn in a vapor flow path creates turbulence that can actually re-entrain separated oil droplets. A streamlined path maintains laminar flow, keeping separated oil out of the airstream.
For owners starting from stock: Combining the ICC with a full reroute kit provides comprehensive oil management. The ICC handles separation at the source; the reroute kit directs the cleaned vapor away from the intake, preventing any residual oil from reaching the turbo and intercooler.
The best of both worlds: This combination achieves the primary goal of keeping oil out of the intake while eliminating the maintenance requirements of external catch cans.
How the ICC helps: By removing a significant portion of the oil droplets before the vapor is either vented or returned to the intake, the ICC reduces the hydrocarbon load in the vapor stream. This results in less noticeable odor and fewer visible oil droplets.
ABS advantages: ABS plastic offers excellent impact resistance, chemical resistance to oil and fuel, and dimensional stability across temperature ranges. It is well-suited for CCV applications where exposure to oil vapor and underhood temperatures is constant.
Anodized metal components: Anodizing provides a hard, corrosion-resistant surface that withstands the chemical environment of the engine bay. The black finish also improves heat dissipation compared to bare metal.
Complete hardware package: The kit includes "all the accessories you need," which means no last-minute trips to the hardware store for missing fittings or clamps.
Why cab & chassis matters: Cab and chassis trucks have different frame lengths, exhaust routing, and body configurations than pickup trucks. Components that fit a crew cab short bed may not fit a cab & chassis truck with a different wheelbase.
The 2011-2023 coverage: The kit fits the entire 6.7L production run through 2023, including F-250, F-350, F-450, and F-550 models. This comprehensive fitment reflects engineering validation across multiple chassis configurations.
The significance: For owners who want to improve their engine's intake cleanliness but cannot or do not wish to modify their ECM calibration, a CCV reroute with ICC provides measurable benefits without the complexity of tuning.
Why this matters: External catch cans are effective but require regular attention. If the owner forgets to empty the can, it fills and becomes a restriction, potentially increasing crankcase pressure. If the can is not cleaned periodically, the separation media can become saturated and lose effectiveness.
The ICC's passive operation: By allowing separated oil to drain back to the crankcase during off periods, the ICC maintains its separation efficiency indefinitely without human intervention. It simply works, quietly and continuously, for the life of the engine.
Cleaner air, better combustion: Every reduction in oil vapor reaching the combustion chamber means fewer hydrocarbons being burned that shouldn't be there. The engine operates on air and fuel, not air and fuel with oil contamination.
Preserved intercooler efficiency: A clean intercooler transfers heat more effectively than an oil-fouled one. Lower intake air temperatures mean denser air charges, which mean more oxygen for combustion and more power from each injection event.
Maintained turbo response: A clean compressor wheel maintains its aerodynamic efficiency, spooling as designed rather than struggling against oil deposits.
Long-term reliability: By eliminating oil from the intake tract, the ICC prevents the gradual degradation that would otherwise occur over hundreds of thousands of miles.
The TruckTok 2011-2023 6.7L Powerstroke CCV PCV Reroute Engine Ventilation Kit with Internal Catch Can addresses this at the source. By integrating the separation chamber into the existing valve cover volume, it achieves effective oil removal without external components, without maintenance requirements, and without the pressure drop that plagues poorly designed separators.
For owners who want to preserve their engine's performance over the long term, this is not an accessory—it's a mechanical correction of an engineering compromise. Cleaner intake air, maintained intercooler efficiency, preserved turbo response, and eliminated oil deposits are the measurable outcomes.
If you've installed a CCV reroute or Internal Catch Can on your 6.7L Powerstroke, what changes have you observed in intake cleanliness, turbo response, or oil consumption? Drop your experience below.
Part 1: The Physics of Blow-By and Crankcase Pressure
Every internal combustion engine produces blow-by. It is the inevitable result of combustion pressure escaping past the piston rings and entering the crankcase. These gases are not inert—they carry atomized engine oil, unburned fuel, water vapor, and combustion byproducts.The factory solution: The 6.7L's CCV system routes these gases through a series of baffles and a separator built into the valve cover. The goal is to capture larger oil droplets and return them to the crankcase while allowing the remaining gases to be drawn into the intake system and reburned.
Part 2: The Bernoulli Principle and the 6.7L's Intake Vacuum
The 6.7L's intake system creates a low-pressure zone using Bernoulli's principle—the same physics that allows an airplane wing to generate lift. As air accelerates through the intake tube, its pressure drops, creating a vacuum that draws crankcase vapors out of the engine.Why this matters: The strength of this vacuum varies with engine load and RPM. At high boost, the intake pressure is actually positive, which means the CCV system must rely on pressure differentials within the crankcase itself to evacuate gases. This varying flow rate affects how much oil vapor is carried into the intake at different operating conditions.
Part 3: The Cascade of Contamination
Once oil vapor enters the intake stream, it follows a predictable path of deposition with measurable consequences.Turbocharger Compressor Wheel Fouling
Part 4: The Internal Catch Can Concept – A Different Engineering Approach
The product description introduces a concept that deserves careful examination: the CCV Internal Catch Can (ICC) . This represents a fundamentally different approach to crankcase ventilation than the external catch cans commonly seen in the aftermarket.How traditional catch cans work: An external canister is installed in the CCV line between the valve cover and the intake. As oil-laden vapor passes through the can, it encounters baffles, mesh, or other media that cause oil droplets to coalesce and collect in a reservoir. The cleaned air continues to the intake. The drawback is maintenance—the reservoir must be emptied periodically, and if forgotten, the can becomes a restriction.
Part 5: The Venturi Effect and Pressure Drop Considerations
The product information emphasizes that the ICC was "carefully designed to ensure minimal pressure drop across the baffles." This is a critical engineering consideration that separates effective designs from restrictive ones.Why pressure drop matters: The CCV system relies on pressure differential to evacuate crankcase gases. If a separation device creates excessive restriction, crankcase pressure can rise, leading to oil seal leaks, gasket failures, and increased blow-by.
Part 6: The Synergy with External CCV Reroute Kits
For owners with existing reroute kits: The ICC can be added to enhance oil separation without replacing the entire CCV system. This allows incremental improvement for those who have already modified their trucks.For owners starting from stock: Combining the ICC with a full reroute kit provides comprehensive oil management. The ICC handles separation at the source; the reroute kit directs the cleaned vapor away from the intake, preventing any residual oil from reaching the turbo and intercooler.
Part 7: The Odor and Vapor Reduction Benefit
Why CCV systems produce odor: The crankcase vapors that are normally routed into the intake and burned contain hydrocarbons that contribute to the characteristic diesel exhaust smell. When these vapors are vented to atmosphere (as in some reroute configurations), the smell can be noticeable, particularly at idle.How the ICC helps: By removing a significant portion of the oil droplets before the vapor is either vented or returned to the intake, the ICC reduces the hydrocarbon load in the vapor stream. This results in less noticeable odor and fewer visible oil droplets.
Part 8: The Material and Construction Quality
The kit is constructed from "high strength ABS and metal material" with "black anodized components for better durability."ABS advantages: ABS plastic offers excellent impact resistance, chemical resistance to oil and fuel, and dimensional stability across temperature ranges. It is well-suited for CCV applications where exposure to oil vapor and underhood temperatures is constant.
Part 9: The Fitment Range – Including Cab & Chassis
The product information explicitly states compatibility with cab and chassis trucks, which is notable because many aftermarket components exclude these configurations.Why cab & chassis matters: Cab and chassis trucks have different frame lengths, exhaust routing, and body configurations than pickup trucks. Components that fit a crew cab short bed may not fit a cab & chassis truck with a different wheelbase.
Part 10: The Tuning Connection – What You Don't Need
Unlike EGR or DPF modifications, CCV reroute does not require tuning. The PCM does not monitor crankcase pressure or CCV flow on the 6.7L. This makes CCV modification one of the few performance-oriented changes that can be made without software changes.The significance: For owners who want to improve their engine's intake cleanliness but cannot or do not wish to modify their ECM calibration, a CCV reroute with ICC provides measurable benefits without the complexity of tuning.
Part 11: The Service-Free Design – Eliminating Maintenance
The product emphasizes that the ICC requires no maintenance—no draining, no cleaning, no replacement of filter elements.Why this matters: External catch cans are effective but require regular attention. If the owner forgets to empty the can, it fills and becomes a restriction, potentially increasing crankcase pressure. If the can is not cleaned periodically, the separation media can become saturated and lose effectiveness.
Part 12: The Performance Rationale
The product information states that the system helps "ensure the strongest combustion and best engine efficiency." This is not marketing hyperbole—it's engineering reality.Cleaner air, better combustion: Every reduction in oil vapor reaching the combustion chamber means fewer hydrocarbons being burned that shouldn't be there. The engine operates on air and fuel, not air and fuel with oil contamination.
Part 13: The Complete Package
The kit includes everything needed for installation:- CCV Internal Catch Can (ICC) integrated replacement
- Complete Venturi system components
- All necessary hardware and fittings
Conclusion: A Technical Assessment
The 2011-2023 6.7L Powerstroke is an exceptional engine, but its factory CCV system still allows oil vapor to enter the intake tract, with predictable consequences for performance and efficiency. The oil that bypasses the factory baffles coats turbocharger wheels, insulates intercoolers, degrades charge air boots, and eventually deposits on intake valves.The TruckTok 2011-2023 6.7L Powerstroke CCV PCV Reroute Engine Ventilation Kit with Internal Catch Can addresses this at the source. By integrating the separation chamber into the existing valve cover volume, it achieves effective oil removal without external components, without maintenance requirements, and without the pressure drop that plagues poorly designed separators.
