How does upgrading to a 3-inch high-flow turbo downpipe affect EGTs and spool up on a stock LMM Duramax?
FabPipes_01
Thinking about dropping a 3-inch high-flow turbo downpipe onto a stock 2007–2010 Duramax LMM, but wondering if it’s truly worth the wrench time? We all hear claims about quicker spool-up and lower exhaust gas temperatures (EGTs), but how does it actually alter the truck's real-world behavior under load?
Does flattening out that restrictive, squashed factory downpipe noticeably reduce backpressure on a stock tune, or do you really need a full setup to feel the difference? If you’ve made the switch, did your VGT turbo wake up faster off the line, and how much of an EGT drop did you see while towing?
Even on a stock tune, swapping out that flattened factory banana pipe for a true 3-inch round downpipe is absolutely worth it. When towing my 12,000-lb camper up a 6% grade, my peak EGTs dropped by a solid 100°F to 150°F.
The factory squashed pipe creates a massive heat pocket right behind the turbo. By flattening out the restriction, you let the heat escape much faster. If you tow heavy, lower EGTs mean peace of mind and less thermal stress on your rear cylinders (numbers 7 and 8), which already run hotter on the LMM.
Dropping a 3-inch high-flow downpipe onto a stock LMM is absolutely worth the effort, even on the factory tune. The stock downpipe has a notorious, squashed "pancake" section that severely chokes out exhaust flow right at the turbo discharge.
By swapping to a true round 3-inch pipe, you dramatically lower backpressure directly behind the turbine wheel. On a stock tune, this reduction in restriction allows the VGT to manipulate its vanes much more effectively. You will definitely notice the turbo waking up faster off the line, cutting down that initial lag and smoothing out your throttle response.
When it comes to EGTs, don't expect miracles during empty daily driving, but you will see a noticeable drop of around 50°F to 100°F while pulling heavy loads up steep grades. It acts as a thermal relief valve for the back of your engine, allowing hot air to escape much quicker before heat saturates the cylinders.
