Hey everyone,
If you’ve owned a 2008-2010 6.4L Powerstroke for more than a week, you’ve likely realized that while this engine is a powerhouse, its factory emissions system is its own worst enemy. We all love the common-rail injection and the compound turbos, but the way Ford/International handled Exhaust Gas Recirculation (EGR) on this platform was, frankly, a disaster waiting to happen.
I’ve spent the last few months "bulletproofing" the top end of my '08, focusing specifically on the EGR system and the cooling circuit. I wanted to put together a comprehensive guide for anyone looking to stop the soot buildup and prevent the dreaded "coolant puking" that claims so many of these trucks.
Q: Is it okay to use the stock Ford Gold coolant?A: Most 6.4L experts recommend switching to a heavy-duty ELC (Extended Life Coolant) that is silicate-free. The silicate in the "Gold" coolant is what often clogs the coolers.
Q: What about the law?A: Here is the legal reality: Removing or bypassing emissions equipment like the EGR system is generally considered a violation of the Clean Air Act in the United States if the vehicle is operated on public roads. These modifications are strictly intended for off-road, competition, or show use only. Be sure to check your state and local regulations before proceeding.
It’s a bit of work, but the peace of mind knowing your EGR coolers won't rupture on the highway is worth every penny.
What’s your next move? If you haven't checked your coolant for sediment lately, I'd highly recommend starting with the filtration kit—it’s the easiest install and the best insurance you can buy for your oil cooler.
Got questions on the install? Drop them below!
Part 1: The Factory Flaws (The "Before" Picture)
Before we get into the "how-to," let’s talk about why the stock 6.4L setup is flawed from the factory.- Soot Saturation: The EGR system works by taking hot, soot-filled exhaust gas and piping it back into your intake manifold to lower NOx emissions. On a 6.4L, this creates a thick, oily "sludge" that coats your intake valves and restricts airflow.
- The EGR Cooler Failure: The 6.4L uses two EGR coolers. These are notorious for leaking internally. When they fail, exhaust gas enters your cooling system, spiking pressures and blowing your head gaskets—or worse, coolant leaks into the cylinders and hydrolocks the engine.
- Contaminated Coolant: The 6.4L cooling system is incredibly sensitive. Residual casting sand and chemical precipitates (silicate dropout) from the factory coolant create a "goo" that clogs the tiny passages in your oil cooler. A clogged oil cooler then starves the EGR coolers of liquid, causing them to crack.
Part 2: The Solution (What Parts to Use)
I went with a two-pronged approach: remove the source of the heat/soot and clean the fluid that keeps the engine alive. I sourced my gear from TruckTok, mostly because their machining quality on the aluminum billet parts is top-tier for the price point.1. The Total Top-End Cleanup: EGR Delete Kit
To get rid of the coolers and the valve entirely, I installed this high-flow EGR delete kit with intake elbow.- The Highlights: This kit isn't just a block-off plate. It includes a polished aluminum high-flow intake elbow. The stock elbow is a mess of sensors and turbulence; this one is smooth and dramatically improves throttle response.
- Why it matters: By removing the EGR coolers, your coolant temperatures naturally run lower because they aren't trying to quench 1,000°F exhaust gas. Plus, the aluminum alloy construction resists the corrosion that typically kills the factory steel units.
2. The Insurance Policy: Coolant Filtration System
Even if you delete the EGR, your oil cooler is still at risk from the "sand" in the block. I added a billet CNC machined coolant filter kit as an absolute necessity.- The Highlights: The base is made of anodized billet aluminum (which looks great under the hood) and uses a non-charged, chemical-free filter.
- Pro-Tip: This kit includes ball valves on the supply and return hoses. Do not buy a kit without valves. These allow you to change the filter without spilling a drop of coolant or having to drain the whole system.
Part 3: The Installation – What to Watch Out For
Installing an EGR delete on a 6.4L is significantly more involved than on the older 6.0L. There are two coolers tucked away, and space is a premium.- The "Hidden" Bolts: Be prepared for the bolts on the back of the EGR coolers to be rusted. Use a high-quality penetrating oil the night before.
- The Intake Elbow: When swapping to the polished aluminum high-flow elbow, ensure your O-rings are seated perfectly. A small boost leak here will make the truck sluggish and throw a code.
- Coolant Filter Plumbing: The coolant filtration kit is a bypass system. It doesn't filter 100% of the flow at once, but rather cleans it continuously as you drive. Make sure your hoses are routed away from the serpentine belt and the radiator fan. I used zip ties to keep everything tucked neatly against the shroud.
Part 4: Post-Install Experience & Gains
I’ve put about 3,000 miles on the truck since the overhaul. Here is the honest feedback:- Intake Temps: My IAT2 (Intake Air Temp 2) plummeted. Without the EGR feeding fire into the intake, the air entering the cylinders is much denser and cooler.
- Oil Clarity: Usually, 6.4L oil turns black as ink within 50 miles of an oil change. Now, it stays amber significantly longer because it isn't being saturated with recirculated soot.
- The Filter Reveal: I cut open my first coolant filter after 500 miles. It was full of what looked like orange glitter and fine sand. That stuff would have been sitting in my oil cooler if it weren't for the filtration system.
Part 5: Common Questions (FAQ)
Q: Do I need a tuner to run this EGR Delete?A: Yes, 100%. If you remove the EGR valve and coolers without a "delete-capable" tune, your truck will immediately enter "Limp Mode" and your dashboard will light up like a Christmas tree.Q: Is it okay to use the stock Ford Gold coolant?A: Most 6.4L experts recommend switching to a heavy-duty ELC (Extended Life Coolant) that is silicate-free. The silicate in the "Gold" coolant is what often clogs the coolers.
Final Verdict
If you want your 6.4L to last past 150,000 miles, you have to address the "junk" in the system. Getting that aluminum EGR delete kit on there stops the soot from choking your engine, and the coolant filter keeps your "lifeblood" clean.It’s a bit of work, but the peace of mind knowing your EGR coolers won't rupture on the highway is worth every penny.
