5InchStraight_02
Is your LB7, LLY, or LBZ Duramax starting to sound like a looping race car at stoplights? That annoying, rhythmic surging at idle is the classic first sign that your factory Fuel Pressure Regulator (FPR) is sticking and failing to control rail pressure.
As the internal spring and pintle wear down, the ECM constantly overcompensates, leading to massive fuel rail pressure spikes that you can actually watch jump around on a live data scanner.
For everyone who has tracked this down: What was your exact diagnosing bottleneck? Did you watch your desired vs. actual rail pressure split on a scan tool, try running a fuel additive clear-out first, or just wait for the hard limp mode to force your hand?
