How to spot a cracked factory exhaust manifold before it ruins your drive?
Ever noticed a strange ticking noise under your hood during a cold start, only for it to vanish once the engine warms up? Or maybe you’ve spotted mysterious black soot dusting your passenger-side shock tower?
The 2007–2012 6.7L Cummins factory exhaust manifolds are notorious for warping and cracking under intense heat cycles, especially back near cylinders #5 and #6. By the time you actually smell raw exhaust in the cab, the warped metal might have already snapped your exhaust studs right out of the cylinder head.
Before it snowballs into a nightmare driveway extraction job, how are you guys diagnosing this early? Are you using the mirror trick, looking for dropped gaskets, or waiting for the telltale hiss under load?
Don't just look for cracks; look for dropped or spinning bolt spacers. The factory Cummins manifold shrinks and warps so violently that it literally shears the heads off the exhaust studs.
Grab an inspection mirror and a extendable magnet, and check the very back bolts near the firewall. Cummins uses thick metal cylindrical spacers under the bolt heads. If you can reach back there and spin that spacer with your fingers, or if you see the spacer is sitting crooked, that bolt is already snapped off inside the cylinder head. If you catch it while the spacer is just loose but the bolt is still intact, you can save yourself a nightmare drilling job on your driveway. If it's already snapped, pray there's enough shank left to grab with a weld-nut.
