In the world of heavy-duty pickups, the RAM-backed 6.7L Cummins I6 is legendary for its 'industrial-grade' longevity. Yet, even this million-mile beast isn't immune to a seizing Holset VGT actuator (P0046) or a clogged CCV filter (P051B) that can stop a haul in its tracks. When that frustrating Check Engine Light illuminates your dash, are you going to start 'parts cannon' guessing, or are you going to pinpoint the exact issue? To help every Cummins enthusiast in the TruckTok community decode these complex electronic signals, we’ve compiled this comprehensive DTC dictionary covering everything from VGT boost and high-pressure rail systems to the 68RFE and Aisin transmissions. Understanding these codes is the only way to truly master the beast under your hood.
### 1. Turbocharging and VGT System (VGT Turbocharger - P00xx / P22xx)
This is Cummins' most representative area of frequent malfunctions. Its Holset turbocharger uses an electronic actuator to control the blade position, making it highly susceptible to carbon buildup or overheating of the circuitry.
P0046: Turbocharger Actuator Performance – Core code. Usually indicates the actuator is unable to move or the internal circuit board is burnt out.
P0299: Underboost – Indicates need to check for intercooler pipe leaks or malfunctioning actuators.
P2262: No Turbocharger Pressure Detected (Mechanical Failure) – Indicates the VGT blades are completely stuck due to carbon buildup, and the sensor cannot read pressure fluctuations.
P2563: Turbocharger position sensor performance.
P0471: Exhaust Pressure Sensor Malfunction.
P0489 / P0490: EGR control circuit low/high (EGR valve malfunction).
### 2. Fuel System - P00xx / P01xx For Bosch high-pressure common rail systems, covering CP3 pump (older models) and CP4 pump (2019-2020 models).
P0087: Fuel Rail Pressure Too Low.
P0148: Fuel Delivery Error – Actual pressure deviates significantly from commanded pressure.
P0191: Fuel Rail Pressure Sensor Malfunction.
P0251: CP3 Pump Flow Control Valve (FCA/MPROP) Circuit Malfunction – May cause unstable idling or severe shuddering.
P0627: Fuel lift pump control circuit (Lift Pump) – Low-pressure pump malfunction located in the fuel tank.
P000F: Fuel system overpressure relief valve activated.
### 3. Injectors & Misfire - P02xx / P03xx Injection logic for inline-six engines.
P0201 - P0206: Open circuit in injector control circuits 1-6 (Note: Cummins only have 6 cylinders).
P0300 - P0306: Single cylinder misfire detected.
P2146 / P2149: Injector group 1 (cylinders 1-3) or group 2 (cylinders 4-6) power circuit malfunction – usually an open circuit in the integrated wiring harness inside the valve cover gasket.
P0216: Fault in fuel injection timing control circuit.
### 4. DPF & Regeneration (P24xx)
This is the main cause of vehicles entering "Limited Speed Mode" and "Power Reduction".
P2463: Excessive DPF Soot Accumulation – Service regeneration required.
P242F: DPF Limitation - Ash Accumulation – Physical blockage, usually requiring disassembly, cleaning, or replacement.
P2459: DPF Regeneration Frequency Too High – Indicates incomplete regeneration or a false alarm from the sensor.
P2453: DPF Differential Pressure Sensor Range/Performance Malfunction – Common fault, water accumulation in the lines, or sensor failure.
P1451: DPF Performance Issue (Regeneration Incomplete).
P241D: Power Reduction Due to Reductant Depletion – This is the final indication of entering "Limp Mode".
### 5. Reductant and Urea System (SCR & DEF - P20xx / P21xx)
Cummins NOx sensors typically have a short lifespan, especially with frequent cold starts.
P207F: Reductant (DEF) Quality Malfunction – The sensor thinks your urea is incorrect or ineffective.
P20E8: Low Reductant Pressure – Check the DEF pump or line filter for blockages.
P2047: Reductant Injector Control Circuit Open Circuit.
P20BA: Reductant Heater 1 Control Performance – Check the heating hose in the urea tank.
P2201: NOx Sensor 1 (Upstream) Circuit Performance.
P229E: NOx Sensor 2 (Downstream) Circuit Failure – A common fault, usually caused by exhaust carbon buildup or sensor burnout.
P20EE: SCR Catalytic Converter Efficiency Below Threshold.
### 6. Special Sensors & Crankcase
P0471: Exhaust Pressure (EBP) Sensor Performance – This is a critical reference value; a faulty sensor directly affects boost pressure.
P051B: Crankcase Pressure Sensor Performance – Important Reminder: If this error occurs, it usually means your CCV filter is clogged and needs replacement (typically every 67,500 miles for 6.7L engines).
P011B: Coolant/Intake Air Temperature Correlation Abnormality.
P2261: Turbocharger Diverter Valve Mechanical Failure.
### 7. RAM Automatic Transmission System (68RFE / Aisin AS69RC - P07xx / P08xx)
P0700: Transmission Control System Fault (General Request Code) – Indicates you need to access the TCM module to read the specific code.
P0731 - P0736: 1st-6th Gear Ratio Incorrect – High-risk code, indicating internal clutch slippage.
P0871: Pressure Switch Rationality Fault – A common electronic fault in the 68RFE valve body.
P0841: Transmission Hydraulic Sensor Performance.
P0933: Hydraulic Line Pressure Sensor Circuit Range/Performance.
P1776: Solenoid Valve Stuck in L/R Position – Causes the vehicle to enter protection mode, preventing shifting to higher gears.
P0741: Torque Converter Clutch (TCC) circuit malfunction.
### 8. Grid Heater & Electrical - P05xx / P06xx
Cummins does not use traditional glow plugs; instead, it uses an intake grille heater.
P0541: Intake Air Heater (IAH) control circuit low level – Check the heater relay.
P2609: Intake Air Heater System Malfunction – Heater not functioning properly.
Important Note: If this code is reported, be sure to check if the "Jiggle Pin/Bolt" is loose to prevent it from falling into the cylinder and causing engine failure.
P0606: PCM processor malfunction (control module error).
P0633: Unprogrammed anti-theft key.
P0641 / P0651: 5V Reference Voltage Circuit A/B Fault – A short circuit in a sensor will cause the entire vehicle to report an error.
P2503: Low Charging System Voltage.
### 9. Communication and Network Faults (Communication - U-Codes)
U0100: Loss of communication with ECM.
U0101: Loss of communication with TCM – If it is an Aisin transmission, check the chassis wiring harness.
U010E: Loss of communication with DEF control module.
U0121: Loss of communication with ABS control module.
U110E: Loss of communication with ambient temperature sensor – Don't underestimate this code; it will cause the A/C air conditioning to malfunction and affect DEF injection.
U1421: Invalid brake pedal data received.
