The 6.7L Cummins "Life Support": Why Owners are Deleting the EGR System
TruckerChief
If you own a 2010-2024 Ram 2500 or 3500, you know the 6.7L Cummins is a powerhouse. However, you’ve likely also dealt with the "clutter" on the passenger side of your engine. The Exhaust Gas Recirculation (EGR) system is designed for emissions, but for many high-mileage owners, it becomes a primary source of mechanical headaches.
Here is what you need to know about the 2010-2024 EGR Valve & Cooler Delete Kit and how it actually impacts your truck.
Part1:What is the "EGR Problem" everyone talks about?
The factory system works by re-routing hot, soot-filled exhaust back into your intake to be burned a second time. While this lowers NOx emissions, it creates several long-term issues:
Carbon Buildup: Soot acts like "engine cholesterol," clogging your intake manifold and sticking to your valves.
The Ticking Time Bomb: The EGR cooler is a thin-walled heat exchanger. Over time, thermal fatigue causes it to crack, leaking coolant into your cylinders and potentially hydrolocking your engine.
Part2:How does a Delete Kit solve this?
A full delete kit like the TruckTok Billet Series physically removes the bulky cooler and valve assembly.
What replaces it? CNC-machined aluminum plates seal the exhaust and intake manifolds, while a high-temp silicone hose reroutes the coolant loop.
The Result: Your engine breathes 100% fresh, oxygen-rich air. No more "re-breathing" its own waste.
Part3:What are the Pros of installing an EGR Delete?
1.How it saves your engine: It eliminates the risk of a cracked cooler dumping coolant into your motor.
2.Lower EGTs: By not pumping 1200°F exhaust back into the intake, your Exhaust Gas Temperatures drop, which is vital when towing heavy loads.
3.Cleaner Oil: Your oil stays amber significantly longer because it isn't being saturated with abrasive carbon soot.
4.Easier Maintenance: Removing the "clutter" gives you instant access to your fuel injectors and the grid heater, saving hours of labor in the future.
Part4:What are the Cons and Risks?
1.Tuning is Mandatory: You cannot simply bolt this on and drive. You must have a tuner (like EZ LYNK or EFI Live) to tell the computer the system is gone, or the truck will enter a 5-MPH "Limp Mode."
2.Emissions Compliance: These kits are strictly for off-road use. If your state requires a visual emissions inspection, you will fail.
3.The Install Headache: On older 2010-2015 trucks, the exhaust manifold bolts are notorious for seizing. You’ll need plenty of penetrating oil and patience.
Part5:How do you know if your truck needs it?
Are you losing coolant with no visible leaks on the ground? (Internal cooler crack).
Is your throttle feeling "sluggish" or do you have a "dead pedal"? (Soot-clogged intake).
Are you planning to keep the truck past the 150,000-mile mark?
The OEM EGR (Exhaust Gas Recirculation) system works by reintroducing high-temperature exhaust gases into the intake manifold. This process carries significant amounts of soot, which mixes with oil mist from the crankcase ventilation system to form a thick, black, and sticky carbon sludge within the intake tract.
The Improvement: By physically deleting the EGR system, the engine now breathes 100% fresh, oxygen-rich cold air. This not only permanently resolves the clogging issues in the intake manifold and MAP sensors but also ensures a faster and more complete combustion process. The direct result is a noticeably sharper throttle response and a much smoother power delivery.
Final Verdict
The 2010-2024 Cummins EGR Delete isn't just about "more power"—it's an insurance policy. It replaces failure-prone factory components with solid hardware, ensuring your 6.7L Cummins lives up to its reputation for million-mile durability.
What’s your experience? Have you noticed a drop in coolant temps after deleting, or are you sticking with the factory setup to stay emissions-compliant? Feel free to leave a comment below!
