Trucktok 2008-2010 6.4L Ford EGT Exhaust Temperature Sensor 8C3Z12B591E
This is the installation process for the ER-0335: 2008-2010 6.4L Ford EGT Exhaust Temperature Sensor 8C3Z12B591E,provided for your reference during installation.
Remove the mudguard liners by unscrewing the bolts and plastic clips securing them, then pull the liners out. If necessary, remove the front passenger-side wheel to create more workspace.
At this point, you will find the EGT sensor directly in front of you, fully exposed and within clear view; you can reach straight in with your tools.
Before removal, generously spray penetrating lubricant onto the threads of the old sensor.
Locate the sensor's electrical connector. Disconnect the black electrical plug. Be careful not to pull forcefully on the wiring harness, as this could damage the vehicle-side socket.
Use a 13mm wrench to loosen the sensor by turning it counter-clockwise. If the sensor is seized by rust and will not budge, try gently tightening it slightly before attempting to loosen it again; alternatively, use a torch to apply localized heat to the mounting bung on the exhaust pipe.
Apply a small amount of high-temperature anti-seize compound to the threads of the new sensor. Crucially, do not allow the anti-seize compound to touch the tip of the sensor probe, as this will result in inaccurate readings.
Thread the new sensor into the exhaust bung by hand. Hand-threading first ensures proper thread alignment and prevents cross-threading. Use a 13mm wrench to tighten it down. Do not overtighten, as this could make future replacements difficult or cause the mounting bung to crack.
Plug the electrical connector back into the vehicle-side socket, ensuring that the wiring harness is routed away from any moving parts or sources of extreme heat.
Reinstall the fender liner and the wheel.​
