Hello everyone. As an installer who spends more time under the hoods of HD trucks than at my own dinner table, I’ve seen the LML platform grow from a "quiet" diesel to a legendary workhorse. However, if you are running a stock 2011-2016 LML, you’re likely dealing with the "holy trinity" of diesel headaches: EGR soot buildup, DPF clogging, and restricted airflow.
Today, I want to walk you through a systematic approach to modifying these trucks using TruckTok components. We aren't just looking for "loud"; we are looking for efficiency, longevity, and real-world utility.
If you’re chasing maximum flow, the TruckTok 2011-2015 5" Downpipe Back Exhaust is the way to go. There are no bungs to mess with, providing an unobstructed flow that really lets the turbo breathe.
Don't forget the Passenger Side Exhaust Up-Pipe. Made from 304 stainless steel with laser-cut flanges, it eliminates leaks that typically rob the turbo of drive pressure.
For towing, the Adjustable Drop Trailer Hitch with a 6" drop/rise is a game changer. Made from premium aluminum, it handles up to 12,000 lbs and keeps your trailer level, regardless of your lift height.
If you have questions about installation, drop a comment below!
1. The Foundation: Exhaust and Emissions (The "Delete" Logic)
The LML's biggest bottleneck is the factory exhaust. Depending on your year, you have to be very careful with fitment. GM switched things up halfway through 2015.For the 2011-2015 Early Models (V-Band Style)
If you have an early LML, you're looking at a V-band clamp off the turbo direct pipe. For these, I highly recommend going with a 4" or 5" setup. The TruckTok 2011-2015 6.6L Duramax LML 4" DPF & CAT Delete Pipe is the standard for off-road reliability, using T-409 stainless steel. It’s a direct replacement that drops the weight and the backpressure.If you’re chasing maximum flow, the TruckTok 2011-2015 5" Downpipe Back Exhaust is the way to go. There are no bungs to mess with, providing an unobstructed flow that really lets the turbo breathe.
For the 2015.5-2016 Models (3-Bolt Flange Style)
Pay attention here. Late 2015 and 2016 models moved to a 3-bolt flange. If you try to put a V-band pipe on a 3-bolt truck, you’re going to have a bad day. The TruckTok 2015.5-2016 LML 4" Downpipe Back DPF Delete Pipe is specifically engineered for this. If you want that deep, throaty diesel growl, the 5" 3-bolt flange version is unmatched for efficiency.The All-in-One Solution (Tuner Included)
You can’t just pull the hardware; you need the software. For those who want a one-and-done purchase, the All-in-One kits are life-savers. They include the Mini Maxx V2 Delete Tuner.- For 2011-2015: The 4" All-in-One Kit or the massive 5" All-in-One Kit covers everything: DPF, EGR, DEF, and CCV.
- For 2015.5-2016: Grab the 2015.5-2016 4" Delete Kit or the 5" variant. These kits ensure faster coolant recirculation and lower EGTs right out of the box.
2. Engine "Sanitization": EGR, CCV, and Intake Flow
The LML literally "breathes" its own exhaust via the EGR and drinks its own oil via the CCV. Let’s stop that.EGR Delete
The TruckTok 2011-2016 LML EGR Valve Cooler Delete Kit is built from billet aluminum and stainless steel. It eliminates soot buildup and prevents high EGTs from flowing back into the engine. From a technical standpoint, this allows for quicker turbo spool and longer engine life.Intake Elbow Bridge
While you’re in there, look at the intake. The TruckTok 2011-2015 Duramax LML Intake Elbow Bridge Kit is a must. It replaces the restricted stock pipes with larger diameter, TIG-welded aluminum tubes. It increases airflow by 80% and includes a resonator delete block to lower those intake temps.CCV Reroute
To prevent "intake gumming" and boot soak, the 2011-2016 LML CCV PCV Reroute Delete Kit is essential. It vents crankcase blow-by using a 100% silicone reinforced hose, freeing up room under the hood and ensuring virtually no oil loss puddles under your truck.3. Tuning and Turbo Response
To manage these changes, a Trucktok 2011-2016 Duramax LML 5 Position Switch is the professional choice. It allows you to switch between tunes (Tow, Street, Performance, etc.) on the fly. The aluminum knob and heat-resistant braided wire are designed for the high-temp environment of an HD engine bay.Don't forget the Passenger Side Exhaust Up-Pipe. Made from 304 stainless steel with laser-cut flanges, it eliminates leaks that typically rob the turbo of drive pressure.
4. Utility: Tonneau Covers and Recovery
A truck isn't just an engine; it's a tool. Protection and recovery are paramount.Tonneau Covers (Soft Roll-Up vs. Hard Tri-Fold)
If you haul tall loads frequently, the Soft Roll-Up is your friend.- 8FT Bed: 2014-2025 Silverado/Sierra 8FT Soft Roll Up
- 6.5FT Bed: 2014-2018 Soft Roll Up
- 8FT Bed: Trucktok 2010-2025 8FT Hard Tri-Fold
- 6.5FT Bed: 2014-2019 Hard Tri-Fold
Recovery and Towing
Never use a static strap to pull an 8,000lb truck. The Trucktok 1" x 30ft Kinetic Recovery Rope uses double-braided Nylon 66 to stretch and "sling" the truck out of mud without snapping. Pair it with the 2" Shackle Hitch Receiver (38,500 lbs break strength) for a safe anchor point.For towing, the Adjustable Drop Trailer Hitch with a 6" drop/rise is a game changer. Made from premium aluminum, it handles up to 12,000 lbs and keeps your trailer level, regardless of your lift height.
Conclusion
Building an LML is about balance. You start with the exhaust—choosing between the 4" or 5" based on your sound preference and ensuring the 3" Downpipe matches your turbo flange. You clean the engine with EGR and CCV deletes, and you wrap it up with a solid tuner and high-quality bed protection.All "Delete" performance parts are strictly for off-road or race use only. Check your local regulations, legal issues will be borne by oneselfIf you have questions about installation, drop a comment below!
