What are the absolute first signs of a sticking VGT turbo nozzle on a 2013-2018 6.7L Cummins?
Is your 2013–2018 6.7L Cummins starting to feel sluggish off the line, or is your exhaust brake acting completely erratic? A sticking VGT turbo nozzle is a notorious headache on these trucks, but catching it early is key before it throws a hard check engine light.
Have you noticed your boost pressures acting unpredictable—either lagging heavily under load or suddenly overboosting? Or maybe your exhaust brake fails to engage smoothly on descents, or stays partially stuck on, making the truck hiss and lose power?
What were the absolute first warning signs on your rig? Did you get a specific code, or did you feel it in the pedal first?
For me, the absolute first warning sign wasn't a check engine light—it was the sound and the pedal feel. I noticed my exhaust brake started sounding incredibly erratic. Instead of that crisp, deep exhaust bark when letting off the throttle, it started making this weird, choked "hissing" sound like a leaking air hose, and the truck would jerk slightly.
What happens is the sliding nozzle ring gets caked in soot and jams partially closed. When I tried to accelerate from a dead stop, the truck felt like it was pulling a 20,000 lbs trailer. The turbo just wouldn't spool up because the vanes were stuck in the wrong position, choking the exhaust flow. I didn't get a hard code like P2262 (Turbo Boost Pressure Not Detected) until two weeks later. If your exhaust brake sounds different or delays for 2-3 seconds before kicking in, your VGT is definitely starting to bind up!
If you want to catch a sticking VGT before the check engine light ruins your day, quit waiting for a symptom you can feel and start watching your factory electronic gauges. On my 2016 Ram 2500, the absolute first sign was an abnormal spike in Exhaust Back Pressure (EBP) relative to actual turbo boost.
Normally, under light acceleration, your boost and drive pressure should climb somewhat linearly. When my sliding nozzle started binding up with carbon soot, I noticed my boost gauge would lag severely at 5–8 PSI, but my exhaust brake gauge/backpressure parameter was skyrocketing way higher than normal. The truck was literally choking on its own exhaust because the stuck nozzle couldn't open up to let the gases flow. If you feel a slight hesitation in the pedal and notice your boost gauge is "lazy" but your fuel economy is dropping, your VGT vanes are definitely dragging. Get a monitor like an Edge Insight to track this!
