FabPlenum_01
Hooking up a heavy trailer to a 2004.5–2005 LLY Duramax is the ultimate test for its cooling system, but it is also where the notorious head gasket issues like to show their face first. We all dread the blown gasket nightmare, but what are the absolute first red flags when the engine is working hard under load?
Does your upper radiator hose stay rock-hard even after the truck has sat and cooled down overnight? Have you noticed the coolant reservoir randomly overflowing or throwing the low coolant light only when pulling a steep grade, even though the temperature gauge looks normal?
What was the exact symptom that made you realize your LLY gaskets were compromised? Did you catch it on a tow, or did a regular pressure test confirm your fears?
