What Are the Early Warning Signs of a Leaky Injector Causing Constant LMM Regens?
Flatbed_Frank78
It’s a classic LMM nightmare: your truck starts dropping into regen every 150–200 miles, and your fuel economy completely tanks. Everyone blames a tired DPF, but a leaky, over-fueling injector can silently choke the filter with raw soot while washing your cylinder walls.
Before dropping thousands on a replacement exhaust filter, how do you catch a hung-open injector early? Are we looking for hazy white smoke at idle, climbing oil levels on the dipstick from fuel dilution, or erratic balance rates on an Edge monitor?
If you’ve diagnosed an over-fueling issue before it melted a piston, what were your telltale warning signs?
I lived this exact nightmare on my 2009 Chevy 2500HD. My regens dropped from every 300 miles down to every 80 miles over the course of two months. My fuel economy went from 15 MPG down to 9 MPG. I kept telling myself 'I'll just wait until spring to replace the DPF,' thinking the filter was just getting tired at 180k miles.
Big mistake. It turned out my #7 injector was stuck partially open. Because I kept driving it and forcing the truck into continuous active regens, the excessive backpressure warped the variable vanes in my turbo, and the raw fuel washed the lubrication off the cylinder wall. By the time I finally lost power on the interstate, I had scored the cylinder wall and melted the edge of the piston. What could have been a $350 single-injector swap turned into a full engine rebuild and a brand new exhaust system that totaled over $5,500. If your LMM is constantly in a regen, park it until you pull data!
