The 2017-2023 L5P Duramax represents a significant evolution in GM's diesel platform. It features a BorgWarner electronically controlled variable-geometry turbocharger, a Denso HP4 high-pressure fuel pump, and a completely redesigned emissions system with a massive catalytic converter mounted directly to the turbo outlet . GM engineers clearly meant business when they developed this engine.
But here's the technical reality that doesn't make it into the marketing materials: the EGR system remains a fundamental compromise. It routes exhaust gas—laden with soot and operating at extreme temperatures—back into your intake stream to satisfy NOx regulations. This design choice has measurable consequences for engine thermodynamics, component longevity, and intake air quality that owners should understand.
However, the fundamental physics haven't changed. The system still:
Real-world shop inspections have documented a concerning pattern: L5P EGR coolers can begin showing signs of internal seepage as early as 60,000 miles, often without triggering a check engine light . This isn't a catastrophic failure mode like some earlier platforms, but it's a steady degradation of a component that manages both exhaust and coolant.
When an EGR cooler develops an internal leak, two things can happen:
The L5P is known for MAP sensor soot fouling . The manifold absolute pressure sensor sits in the intake manifold, directly exposed to the recirculated exhaust stream. When the EGR system deposits carbon on this sensor, it sends inaccurate readings to the ECM, affecting fuel delivery and combustion.
Symptoms include rough idle, stalling, hesitation, and incorrect air-fuel ratios . The root cause isn't a bad sensor—it's the EGR system contaminating the sensor environment.
Thermal Load on the Cooling System
The EGR cooler acts as a heat exchanger, transferring exhaust heat into the engine coolant. This is heat that wouldn't otherwise be in the cooling system. Under sustained heavy towing, this additional thermal load contributes to elevated coolant temperatures and can push the system closer to its limits .
GM went to extraordinary lengths to secure the L5P's Engine Control Module. When the engine launched in 2017, industry experts believed the ECM might be "uncrackable" . GM cited safety concerns related to autonomous vehicle technology, but the effect was the same: the ECM was heavily encrypted, preventing unauthorized access.
The current reality: ECM unlocking is possible, but it's not a simple OBD-II flash. HP Tuners developed a solution requiring internal circuit board modification . Your ECM must be physically sent out for modification, or you must work with a tuner who has the specialized hardware.
This means: Hardware installation alone is insufficient. Without proper ECM unlocking and delete tuning, the truck will immediately enter limp mode, throw multiple fault codes, or fail to start . The ECM is programmed to monitor EGR flow, valve position, and temperature differentials. Removing the hardware without addressing the software guarantees operational failure.
Removing the EGR cooler from the coolant circuit is a thermodynamic improvement. The coolant no longer absorbs exhaust heat, which reduces the overall thermal load on the radiator and allows the cooling system to focus on its primary job: managing engine heat . This is particularly beneficial under sustained heavy towing where cooling capacity is most stressed.
2. Intake Air Quality Restoration
With the exhaust manifold port sealed, the flow of soot-laden gas into the intake is permanently halted. This prevents future carbon buildup in the intake manifold, on the valves, and on the turbocharger compressor wheel. The MAP sensor remains clean, ensuring accurate airflow readings .
3. Exhaust Gas Temperature Reduction
The EGR system inherently raises EGTs by introducing hot, inert gas that displaces oxygen. Removing it allows the engine to breathe cleaner, cooler air. Engineers who have analyzed L5P trucks under load consistently note that EGTs stabilize and drop significantly after EGR deletion, particularly during extended uphill towing .
4. Elimination of Regen-Related Complications
While the DPF is a separate system, the EGR contributes to soot loading. Deleting EGR reduces the soot entering the exhaust stream, which can reduce DPF regeneration frequency and the associated fuel penalty .
The TruckTok 2017-2023 L5P EGR Delete Kit addresses these criteria with:
What proper delete tuning accomplishes:
The EGR system remains its most significant engineering compromise. It adds heat to the cooling system, contaminates the intake tract with soot, introduces a component subject to thermal fatigue, and directly contributes to sensor fouling issues that affect drivability.
For owners operating in jurisdictions where emissions compliance is not a factor and who are prepared to invest in proper ECM unlocking and tuning, a complete EGR delete is a technically sound modification. It lowers operating temperatures, eliminates a known contamination source, and removes a component with a documented service life.
The TruckTok L5P EGR Delete Kit provides the necessary hardware: billet aluminum components, stainless steel block-off plates, high-temperature silicone hoses, and all required fasteners. It's engineered to be permanent, durable, and correctly configured for the L5P's specific packaging constraints.
When paired with professional tuning from a source that understands the L5P's encrypted ECM requirements, this combination transforms the engine's operating environment from one of compromise to one of mechanical efficiency.
*If you've modified the EGR system on your L5P, what changes have you observed in coolant temperatures, EGTs, or intake cleanliness? Data points and real-world experience are welcome below.*
Part 1: The L5P's EGR System – Engineering Context
The L5P's emissions architecture is more sophisticated than previous generations. It combines cooled EGR with a Diesel Oxidation Catalyst, DPF, and Selective Catalytic Reduction system. The EGR cooler itself was upgraded compared to the LML, with larger capacity and improved flow .However, the fundamental physics haven't changed. The system still:
- Taps exhaust gas from the manifold
- Routes it through a cooler that uses engine coolant to reduce temperatures
- Passes that cooled (but still soot-laden) gas through an electronically controlled valve
- Introduces it back into the intake stream
Part 2: Documented Failure Modes on the L5P Platform
EGR Cooler Failure – Earlier Than You'd ExpectReal-world shop inspections have documented a concerning pattern: L5P EGR coolers can begin showing signs of internal seepage as early as 60,000 miles, often without triggering a check engine light . This isn't a catastrophic failure mode like some earlier platforms, but it's a steady degradation of a component that manages both exhaust and coolant.
- Coolant enters the exhaust stream: Burns off as white smoke, results in unexplained coolant loss without visible external leaks.
- Exhaust gases enter the cooling system: Pressurizes the coolant, can cause overheating, and in severe cases forces coolant out the overflow.
Part 3: What Makes the L5P Different – The ECM Encryption Challenge
If you're considering EGR modification on the L5P, there's a critical technical hurdle that didn't exist on earlier Duramax generations.GM went to extraordinary lengths to secure the L5P's Engine Control Module. When the engine launched in 2017, industry experts believed the ECM might be "uncrackable" . GM cited safety concerns related to autonomous vehicle technology, but the effect was the same: the ECM was heavily encrypted, preventing unauthorized access.
Part 4: The Technical Benefits of EGR Deletion
1. Elimination of the Cooler as a Failure PointRemoving the EGR cooler from the coolant circuit is a thermodynamic improvement. The coolant no longer absorbs exhaust heat, which reduces the overall thermal load on the radiator and allows the cooling system to focus on its primary job: managing engine heat . This is particularly beneficial under sustained heavy towing where cooling capacity is most stressed.
Part 5: Material Science and the TruckTok Solution
When evaluating an EGR delete kit, engineers look at three things: material selection, sealing integrity, and coolant flow management .The TruckTok 2017-2023 L5P EGR Delete Kit addresses these criteria with:
- Billet Aluminum Components: CNC-machined for precision fit, with hard anodizing for wear and corrosion resistance. This is a permanent replacement for factory castings that are subject to fatigue.
- Stainless Steel Block-Off Plate: Seals the exhaust manifold port with a material that won't corrode or fatigue over time. Stainless maintains integrity at exhaust temperatures where mild steel would eventually degrade.
- High-Temperature Silicone Coolant Reroute Hose: Silicone is specified specifically for its resistance to oil exposure and thermal cycling. Standard rubber would degrade in this application.
- Complete Hardware Package: All necessary fasteners are included, ensuring proper clamping force and sealing.
Part 6: The Tuning Imperative – Non-Negotiable Reality
For the L5P, the relationship between hardware and software is absolute. Physical deletion without corresponding ECM modification results in a non-functional vehicle .What proper delete tuning accomplishes:
- Disables EGR flow tables and valve actuation commands
- Suppresses diagnostic trouble codes for the missing components
- Optimizes fuel delivery parameters for the new airflow characteristics
- Maintains proper transmission behavior through torque management
Conclusion: A Technical Assessment
The 2017-2023 L5P Duramax is arguably the most robust engine GM has produced. Its core architecture—the block, rotating assembly, fuel system, and turbocharger—is capable of exceptional reliability and performance.The EGR system remains its most significant engineering compromise. It adds heat to the cooling system, contaminates the intake tract with soot, introduces a component subject to thermal fatigue, and directly contributes to sensor fouling issues that affect drivability.
