What are the warning signs that your 6.0L Powerstroke’s factory top-end system is silently clogging your oil cooler?
NoDef_01Guy
The 6.0L Powerstroke oil cooler is a ticking time bomb when the factory top-end emission system starts cooking the coolant. The scariest part? It happens completely in silence until it’s too late. We all know about watching the Delta—the temperature spread between your EOT and ECT—but what are the earlier, more subtle warning signs before that delta hits the danger zone? Are you guys noticing localized coolant weeping, erratic fan clutch engagement, or tiny degas bottle residues first?
What did your gauges look like right before your oil cooler completely clogged?
Before your EOT/ECT Delta ever hits that magic 15-degree danger zone, your Degas Bottle cap will tell you the truth. If you open your hood and notice a crusty, chalky white residue or soft white stains running down the sides of the coolant reservoir right around the pressure cap, your oil cooler is already restriction-bound.
Here is the silent chain reaction: as the tiny water passages inside the oil cooler clog with silicate gel, it slows down the volume of coolant feeding directly into the EGR cooler downstream. The EGR cooler now becomes an absolute furnace, flash-boiling the stagnant coolant into localized steam pockets. This sudden steam pressure forces the 16-psi degas cap to vent, purging micro-clouds of atomized coolant onto the bottle. If you are constantly wiping 'white powder' off your reservoir, your oil cooler is actively choking your top end.
