I’ve owned my 2014 RAM 2500 for several years, and if you’re a 6.7L Cummins owner, you know these trucks are legendary for their torque and longevity. The 6.7L is a workhorse, but like any modern diesel, it has a few "bottlenecks" from the factory that hold it back from its true potential.
One of the most overlooked restrictions isn't in the exhaust—it’s right on top of the engine. I’m talking about the factory intake horn. After dealing with high EGTs while towing, I decided to swap mine for a 3.5-inch High Flow Intake Manifold Elbow. Here’s a deep dive into why this mod is a game-changer for the 2007.5-2018Cummins.
The factory unit has a "crushed" profile with sharp internal bends and a restrictive diameter. This creates massive turbulence. Your turbo is working hard to compress air, only for that air to hit a literal wall of resistance before it can reach the cylinders. This leads to:
● Heat Soak: Restricted airflow means the engine runs hotter, especially under load.
● Turbo Lag: The "dead pedal" feeling is often exacerbated because the air can't get into the plenum fast enough.
● Soot Buildup: If you still have your EGR intact, that restrictive horn becomes a magnet for carbon soot, further choking the engine over time.
The 3.5-inch High Flow Elbow caught my eye for a few specific reasons:
● True 3.5" Diameter: It offers a significantly larger cross-section than stock, allowing for a much higher CFM (cubic feet per minute) of airflow.
● Smooth Mandrel Bends: The air flows through a consistent, smooth curve. No turbulence, no "dead zones".
● Built-in NPT Ports: It comes pre-tapped with dual 1/8" NPT ports. This is huge if you ever want to add a mechanical boost gauge or a water-methanol injection kit later on.
● Heavy Duty Construction: Most are made from thick-walled aluminum or steel with a high-quality powder coat that looks great in the engine bay.
With the 3.5-inch elbow installed, the airflow path is straightened out. The pressurized air from your intercooler now has a direct, high-volume path into the engine. Because the air moves more efficiently, the cylinders fill more completely, which improves the combustion cycle.
● Lower EGTs: This was the biggest win. I saw a consistent drop of 50°F to 100°F in exhaust gas temperatures while cruising and under heavy throttle. That’s a massive safety margin for your head gasket and turbo.
● Faster Turbo Spool: The turbo hits its target boost pressure noticeably faster. The truck feels "lighter" on its feet, and the throttle response is much crisper.
● Increased "Turbo Whistle": You can actually hear the air moving. It gives the Cummins that signature deep growl and a more pronounced spool-up sound that every diesel owner loves.
● Better Engine Efficiency: While I didn't see a massive jump in MPG, the engine feels like it's working much less to maintain highway speeds.
No. Unlike a DPF delete, this is a mechanical airflow upgrade. Your MAF and MAP sensors will simply see better airflow. It works perfectly on stock trucks and highly modified ones alike.
What is the fitment like, and is it a "drop-in" install?
Yes. It’s designed to bolt directly to the factory intake plate. It uses the same 4-bolt pattern. Just make sure you get a fresh gasket for a leak-free seal.
How hard is the install?
It’s a "level 1" DIY job. You’ll need basic sockets and about 30-60 minutes. The hardest part is usually just wiggling the factory boots off the intercooler pipe.
Does it work with the factory grid heater?
Yes, it sits right on top of it. However, many guys choose to do a "grid heater delete" or an upgraded plate at the same time to really maximize the flow.
Upgrading to a 3.5-inch High Flow Intake Horn is a definitive move for Cummins owners looking to balance efficiency and longevity.
After Upgrade (3.5" High Flow Elbow)
● Pros: Significant reduction in EGTS (50-100°F); much faster turbo spool-up and crisper throttle response; includes NPT ports for easy boost/meth injection expansion.
The 3.5-inch High Flow Intake Manifold Elbow is one of the best "bang-for-your-buck" mods you can do. It lowers temperatures, improves response, and prepares your truck for any future power upgrades. It’s a foundational piece of a reliable Cummins build.
Have you upgraded your intake horn yet? Did you notice the EGT drop right away?
How has your 6.7L been breathing lately? Let’s talk airflow!
The Problem with the Factory Intake Horn
The stock intake horn on the 6.7L is a cast aluminum piece designed more for manufacturing convenience and emissions packaging than for performance. If you take it off and look inside, you’ll see why it’s a problem.The factory unit has a "crushed" profile with sharp internal bends and a restrictive diameter. This creates massive turbulence. Your turbo is working hard to compress air, only for that air to hit a literal wall of resistance before it can reach the cylinders. This leads to:
Why I Chose the 3.5-inch High Flow Elbow
I spent some time looking at different intake upgrades. You can find massive side-draft systems, but for a daily driver and tow rig, I wanted something that was a direct "drop-in" replacement without requiring me to relocate fuel lines or spend thousands.The 3.5-inch High Flow Elbow caught my eye for a few specific reasons:
What the Upgrade Actually Does
This elbow replaces the restrictive factory horn from the intercooler pipe to the intake plenum. By opening up this pathway, you are essentially "un-choking" the engine’s lungs.With the 3.5-inch elbow installed, the airflow path is straightened out. The pressurized air from your intercooler now has a direct, high-volume path into the engine. Because the air moves more efficiently, the cylinders fill more completely, which improves the combustion cycle.
Real-World Results After Installation
After running this setup for several months, including a few heavy tows through the mountains, the results were undeniable.● Lower EGTs: This was the biggest win. I saw a consistent drop of 50°F to 100°F in exhaust gas temperatures while cruising and under heavy throttle. That’s a massive safety margin for your head gasket and turbo.
Common Questions
Do I need a tune to run this?No. Unlike a DPF delete, this is a mechanical airflow upgrade. Your MAF and MAP sensors will simply see better airflow. It works perfectly on stock trucks and highly modified ones alike.
Before Upgrade (Factory Horn)
● Cons: Severe airflow restriction due to the "crushed" cast design; higher EGTs while towing; increased turbo lag and "dead pedal" feel.After Upgrade (3.5" High Flow Elbow)
The Verdict
The 2007.5–2018 6.7L Cummins is a powerhouse, but it’s only as good as the air it can breathe. The factory intake horn is a literal choke point that keeps your EGTs high and your throttle laggy.The 3.5-inch High Flow Intake Manifold Elbow is one of the best "bang-for-your-buck" mods you can do. It lowers temperatures, improves response, and prepares your truck for any future power upgrades. It’s a foundational piece of a reliable Cummins build.
