I picked up my 2020 Ram 1500 Quad Cab about two years ago, and like most people who buy these trucks, I intended to use it. Not just pavement pounding, but actual truck stuff—hauling materials, hitting job sites, taking it off-road when needed. The problem with actually using a truck is that the interior takes a beating faster than anything else.
The factory carpet in these new Rams is nice. Too nice, really, for a truck that's going to see mud, snow, and whatever else gets tracked in. After the first winter, I noticed the driver's side carpet starting to look matted down. Salt stains that wouldn't vacuum out. Little spots where water had soaked in and left marks.
I knew I needed floor mats. Not the cheap universal ones that slide around and curl up, but something that would actually protect the investment. After trying a couple options, I landed on a set of Trucktok 2019-2024 Dodge Ram 1500 Quad Cab All-Weather TPE Floor Mats that have completely changed how I think about interior protection.
Here's what I learned about keeping a new Ram clean without losing your mind.
The Problem with Factory Carpet in a Truck You Actually Use
The 2019-2024 Rams have really nice interiors. Ram stepped up their game with materials, fit and finish, and overall quality. The carpet is thick and plush. It looks great in the showroom.
But carpet in a truck that sees real use has a short lifespan. Every time you get in with muddy boots, that dirt grinds into the fibers. Snow melts and soaks in before you even notice. Coffee spills, oil from equipment, dust from job sites—it all ends up ground into the carpet.
Once carpet is stained or worn, there's no good fix. You can clean it, but you'll never get it back to new. The fibers mat down permanently. The stains set in. And replacing carpet in these trucks is a massive job involving seat removal and hours of labor.
The smart move isn't trying to keep the carpet clean. It's keeping the carpet from getting dirty in the first place.
Why TPE Beats Rubber and Carpet
The material in these mats is TPE—thermoplastic elastomer. If you're used to old-school rubber mats, there are some big differences worth knowing.
Rubber mats have a few problems that become obvious over time. They smell, especially when the truck sits in the sun. They can get stiff in cold weather and crack as they age. They're heavy, and they often curl at the edges.
TPE solves all of that. It stays flexible from well below freezing to hot summer days. There's no rubber smell, even when the truck has been baking in the sun. It's lighter than rubber but just as tough. And it doesn't get brittle with age or exposure.
The material is also naturally non-stick. Mud dries and flakes off. Spills bead up instead of soaking in. Nothing really bonds to it, which makes cleaning almost effortless.
What Temperature Testing Tells You
These mats are tested from -40°F to 158°F. That range matters if you live anywhere with real seasons.
At -40, some materials get brittle and crack. Not these. They stay flexible enough to install and remove without breaking.
At 158, which is about what a dark interior can hit in summer sun, cheap mats get soft and start to smell. TPE holds up fine. No odor, no deformation, no problems.
The Fit Difference
Universal mats are a compromise. They sort of fit, but not really. They slide around. They don't cover the transmission hump properly. They leave gaps where dirt can get through.
These mats are laser-scanned from actual truck floors. Every contour matches exactly. The edges come up where they need to contain spills. The middle section lines up perfectly with the transmission tunnel.
The result is a mat that doesn't move. No sliding, no bunching, no curling. It just sits there, covering everything it should cover and staying out of everything it shouldn't.
OEM-Style Retention Clips
The 2019-2024 Rams have factory retention posts in the floor. Cheap mats either ignore these or have holes that don't line up.
These mats are equipped with clips that match the factory setup. They lock into place and stay there. No sliding forward under the pedals, no shifting around corners. The driver's mat stays exactly where it should be, which is a safety feature as much as a convenience.
What You Get in the Set
For the Quad Cab, you get three pieces. Two for the front row—driver and passenger. One for the second row that covers the whole back floor area.
The front mats have raised edges that contain whatever you track in. Mud, snow, water, salt—it all stays in the mat instead of running onto the carpet. The driver's side leaves plenty of clearance around the pedals.
The rear mat is one continuous piece. If you've got kids, dogs, or passengers who don't care about keeping things clean, this is essential. Everything that happens back there lands on the mat, not your carpet.
Cleaning Is Almost Too Easy
This is the feature that sells most people. When the mats get dirty, you pull them out and hose them off.
That's it. No scrubbing. No special cleaners. No hauling them to the car wash. Just a hose and a few seconds.
Mud rinses away instantly. Salt dissolves and disappears. Spills that would permanently stain carpet wash off like they never happened. If they're really caked with dried mud, you might need to let them soak for a minute, but usually water takes everything with it.
Let them drip dry for a few minutes and put them back in. They look brand new every time.
The Under Seat Storage Note
There's a specific fitment note worth paying attention to. These mats are for Quad Cab trucks without rear under-seat storage.
The Ram 1500 Quad Cab has a rear seat that folds up. Some models have storage bins under the seat that change the floor shape. These mats are made for the standard floor without those bins.
If your truck has the under-seat storage, these won't fit correctly. Check your configuration before ordering.
How They Hold Up Long-Term
I've had a set in my truck for about a year and a half now. They've been through mud, snow, salt, sand, and plenty of spills. They still look new.
No warping. No cracking. No fading. The edges haven't curled. The surface hasn't worn smooth where my heel rests.
The truck has been through temperatures from single digits to triple digits. The mats have taken everything without complaint.
Why Your Cab Configuration Matters
These are specifically for the Quad Cab, which is Ram's name for the crew cab with four full-size doors and a decent back seat.
They won't fit Regular Cab trucks—those have no back seat and a different floor shape. They won't fit Mega Cab trucks either, which have a larger back seat area with different contours.
If you've got a 2019-2024 Ram 1500 Quad Cab without the under-seat storage, these are made for your truck.
The Value of Good Floor Mats
Good floor mats aren't the cheapest option. You can spend less on universal mats or thin rubber.
But cheap mats don't last. They curl, they crack, they smell, and they let dirt get through anyway. Over the life of the truck, you'll replace them multiple times.
Quality mats cost more upfront, but they last as long as you own the truck. When you factor in the cost of cleaning carpet or the impossibility of replacing it, good mats pay for themselves pretty quickly.
Final Thoughts
The 2019-2024 Rams are nice trucks. The interiors are well-designed and comfortable. Keeping them that way takes a little effort, but good floor mats make a huge difference.
With the right mats, you can use your truck the way it's meant to be used without trashing the interior. Mud, snow, spills—it all stays on the mat. A few seconds with a hose and everything looks new again.
After a year and a half with these, I can't imagine going back to anything else. The truck stays clean inside no matter what I track in.
If you've tried different floor mats in your Ram, what worked and what didn't? Drop your experience below.
The Fit Difference
Final Thoughts
