Will the highly-complicated ZF 8-speed cost us a $12k repair bill once it’s out of warranty?
Rigid6BT
I’m currently cross-shopping a leftover 2024 RAM 3500 with the commercial-grade Aisin 6-speed versus a new 2026 model with the ZF 8-speed. I know the ZF drives like a luxury car, but what is the real long-term reliability prognosis here?
The Aisin is a loud, clunky dump-truck transmission, but we know it can survive 300k miles of pure abuse. This new ZF is packed with advanced electronics, multi-plate clutch packs, and tight tolerances. Are we looking at another Ford/GM 10-speed situation where the valve bodies start sticking at 60k miles, or did ZF actually build a commercial-grade tank this time? I keep my trucks for 10+ years and I'm terrified of high-tech tranny failures.
If you want to avoid that 5-figure nightmare, you have to throw the old-school maintenance intervals out the window. RAM might tell you the fluid is 'lifetime' or good for 100k miles—don't believe it. Highly-engineered, multi-clutch ZF boxes are incredibly sensitive to heat and micro-debris friction. Flush that fluid and swap the filter every 30k to 40k miles, especially if you're pulling a heavy camper. Keeping the oil clean prevents the tiny fluid passages in the valve body from clogging and keeps the solenoids from sticking. Spending $300 on a fluid service every few years is how you make sure you never see that $12,000 invoice.
