This is the installation process for the TH-0020: 10 Ton Winch Snatch Block 22,000 lbs Heavy Duty Off-Road Recovery Pulley, for your reference during the installation process.
Rotate the two side panels of the pulley block to offset them, exposing the internal pulley grooves.
Wind the winch cable into the pulley grooves. Rotate the side panels again to align them, ensuring the cable is completely wrapped between the two side panels.
Use D-shaped shackles or thread the cable through the connection holes at the top of the pulley block. Ensure both ends of the rotating pulley block are securely connected.
Step 2:Wind the winch cable into the pulley grooves. Rotate the side panels again to align them, ensuring the cable is completely wrapped between the two side panels.
