This is the installation process for the ER-0133: 2007.5-2018 6.7L Dodge Cummins 2500 3500 CCV Black Crankcase Ventilation Diesel,provided for your reference during installation.
Use pliers to remove the hose clamps connected to the ventilation hoses at both ends of the valve cover.
1.Follow that same hose down and remove hose clamps that are down towards the turbo. Pull the hose out.
2.Note: If your truck is a 2019+, cut the factory hose near the compressor housing and install the provided plug.
Press the provided plug into the lower hose connected to the turbine inlet and secure it with a clamp.
1.Install the filter onto the 90 degree bend provided in the kit and secure it with clamps.
2.Install the connected filter onto the valve cover of the previously removed ventilation pipe.
2009-2019 6.7L Dodge Ram Cummins Coolant Bypass Barb Leak repair Adapter Kit
2007-2018 6.7L Dodge RAM 2500 3500 Cummins Diesel 3.5inch High Flow Intake Manifold Elbow Tube Horn
2007-2009 6.7L Dodge Ram Cummins Diesel EGR Delete Kit
2010-2012 6.7 Dodge Ram Cummins 4" Turbo-Back DPF Delete Pipe
2007.5-2012 6.7L Dodge Ram Cummins 2500/3500 4" DPF Delete Race Pipe
2007.5-2012 6.7L Dodge Ram Cold Air Intake w/Filter
2013-2018 6.7L Ram Cummins Diesel EGR Cooler Throttle Valve Delete Kit
2013-2018 6.7L Ram Cummins 5" Turbo Back DPF Delete Pipe (With Muffler )
2013-2018 6.7L Dodge Ram Cummins 4" Downpipe back DPF Delete Pipe
2013-2018 6.7L Ram 2500 3500 Turbo Diesel 4" Exhaust Tube Pipe Kit
