2011-2016 Chevy Duramax LML 5 Position Switch
This is the installation process for the ER-0296: 2011-2016 Chevy Duramax LML 5 Position Switch,provided for your reference during installation.
ER-0296
Open the hood, first disconnect the negative terminals of both power sources, locate the hood release rubber seal on the driver's side firewall, and then pull it out.
Locate the Engine Control Module (ECM), which is typically located in the front of the engine compartment on the driver's side, near the battery. First, remove the bracket from the ECM, then disconnect the first ECM closest to the cab from its connector.
Carefully thread the wire through the hole where the rubber gasket was removed earlier into the engine compartment from the cab. Ensure the wire on the engine compartment side is long enough to connect to the Engine Control Module (ECM) harness.
Use the conduit provided with the switch to protect the switch wire from high temperatures. Carefully reinstall the hood latch rubber gasket around the harness.
Remove the cover from the ECM harness that was removed in step 2.
Remove the panel with many pinholes on the side where the connector is inserted.
Locate pins #11 and #35 of the ECM.
This step only applies to 2011 model trucks. Use a pry bar or paperclip to insert between the pin and the device gap of pin #11 to pop out the yellow pin of pin #11.
Insert the yellow wire into pin #11 and the black wire into pin #35, ensuring they are fully inserted into the bottom of the ECM connector.
Install the panel with multiple pinholes on the connector insertion side and the ECM harness cover.
Finally, reconnect the ECM connectors to the ECM. The engine compartment installation is now complete.
Turn the ignition switch to the "ON" position. Press the small white test button on the back of the switch. If one of the LEDs lights up, the pins are in the correct position. If none of the LEDs light up, check the wiring connections.
Step 13:
Drill a small hole of appropriate size on a suitable panel near the dashboard in the driver's cab and install the switch.
Step 14:
Secure the switch harness to the other harnesses below the dashboard using electrical tape or cable ties.
2011-2015 6.6L GMC Chevrolet Duramax LML Diesel Intake Elbow Bridge Kit
2011-2016 6.6L GMC Chevy Duramax Diesel LML EGR Valve Cooler Delete Kit
2011-2015 6.6L GM Duramax LML 4"/5" Downpipe Back DPF Delete Race Pipe
2015.5-2016 6.6L GM Duramax LML 4"/5" Downpipe Back DPF Delete Pipe
2015.5-2016 Chevy/GMC Duramax LML 4" DPF & CAT Delete Pipe(With Muffler)
2011-2015 Chevy/GMC Duramax LML 4" DPF & CAT Delete Pipe (with Muffler)
2011-2016 6.6L Chevy Duramax LML CCV PCV ReRoute Delete Kit
2011-2015 Chevy/GMC 6.6L Duramax LML Turbo Diesel 3Inch Downpipe Exhaust
