If you own a 2011-2022 6.7L Powerstroke, you’re driving one of Ford’s most capable modern diesel engines. Yet, even this robust platform has areas where strategic modifications can significantly enhance long-term reliability, unlock performance potential, and tailor the truck to your specific needs. As a technician who’s worked on countless examples across this entire production span, I’ve seen the patterns. This guide isn’t about chasing peak dyno numbers; it’s about a logical, component-by-component approach to building a more dependable and responsive truck, using well-engineered parts that address specific goals. We’ll navigate the crucial years, identify the right parts for your truck, and build from the engine bay outward.
Part 1: Addressing the Core – Emissions System Management (EGR & DPF)
The factory Exhaust Gas Recirculation (EGR) and Diesel Particulate Filter (DPF) systems are the primary constraints for those seeking ultimate reliability and reduced maintenance. While more durable than previous generations, they still introduce complexity, heat, and restriction.
Removing the EGR and DPF without reprogramming the engine computer will result in a non-functional truck stuck in “limp mode” with a dashboard full of warning lights. A proper tuner is not optional; it’s the brain of the operation.
Modern tuners like the EZ Lynk Auto Agent or H&S Mini Maxx V2 serve three critical functions: they disable the diagnostics for the removed emissions components, recalibrate engine parameters (fueling, timing, turbo control) for optimal and safe operation with the new hardware, and allow you to safely access multiple performance levels.
Key Year Note for Tuners & Accessories: Pay close attention to model year splits, as tuning requirements differ.
For a streamlined, guaranteed-compatible installation on 2011-2019 pickup trucks, an all-in-one kit is highly recommended. These bundles provide everything needed in one purchase:
With the major systems handled, these upgrades support better engine health and response.
A well-running truck should also be a useful and secure one.
Successfully modifying your 6.7L Powerstroke hinges on a clear understanding of your goals (reliability, performance, or both) and your truck’s specific details—most importantly, its model year and whether it’s a pickup or a Cab & Chassis. The sequence is logical: address emissions systems and tuning first, then support with intake and airflow mods, and finally add functional upgrades. For 2011-2019 pickup owners, an all-in-one kit represents the most efficient path. Always consult with your tuner provider to ensure software compatibility for your specific vehicle. By following this structured, component-aware approach, you can build a 6.7L Powerstroke that is not only more powerful but also more dependable and better suited to your work or play.
- EGR System Delete: Removing the EGR system stops the flow of soot and extreme heat back into the intake manifold. This results in a cleaner engine, lower intake air temperatures, and the complete elimination of potential EGR cooler leaks. A quality delete kit is essential. Kits like the CNC-Machined EGR Delete Kit for 2011-2023 6.7L Powerstroke or the Black Anodized EGR & Cooler Delete Kit are typical solutions. They include block-off plates (often with pre-drilled holes for factory exhaust gas temperature probes, like 10mm or 12mm) and components to maintain proper coolant flow, preventing overheating issues. The black anodized versions offer superior corrosion resistance for a clean, long-lasting install.
- DPF System Removal:The DPF is the single largest exhaust restriction. Deleting it dramatically reduces exhaust backpressure, which lowers Exhaust Gas Temperatures (EGT) and allows the turbo(s) to operate more efficiently. Your choice depends on your truck’s configuration and desired flow:
- 4” DPF Delete Pipe: A standard and effective upgrade. The 4" DPF & Cat Delete Pipe for 2011-2023 Pickups is a direct replacement made from T409 stainless steel. It’s a great all-around choice for most trucks. Crucially, this and most other “delete pipes” do NOT fit Cab & Chassis models.
- 5” Downpipe-Back System: For maximum flow and sound, a full 5" Downpipe Back DPF Delete Race Pipe is the performance option. Starting at the turbo downpipe, it provides the least possible restriction. Note: This also does not fit Cab & Chassis trucks.
- For 2011-2019 Trucks: You can use the EZ Lynk Auto Agent 3 Tuner for 2008-2019 Models. For trucks with compatible custom tuning, a Shift-on-the-Fly (SOTF) Switch for 2011-2014 or for 2015-2019 allows you to change power levels from the cab.
- For 2020-2022 Trucks: These require the newer EZ Lynk Auto Agent 3 Tuner specific to 2020-2022 due to changes in Ford’s encryption.
- The 4" Complete System: The 4" DPF/DEF/EGR/CCV All-in-One Kit for 2011-2019 includes the 4” exhaust, EGR delete, CCV reroute, and the Mini Maxx V2 tuner.
- The 5" Complete System: For max performance, the 5" DPF/DEF/EGR/CCV All-in-One Kit for 2011-2019 offers the full 5” downpipe-back exhaust with all related components and tuner.
- CCV/PCV Reroute & Catch Can: The factory crankcase ventilation (CCV) routes oily vapors back into the intake. A CCV Reroute Kit for 2011-2023 6.7L vents these gases to the atmosphere or into a CCV Catch Can, keeping your intake system clean and reducing oil residue in the intercooler and piping. This is a key mod for longevity, especially on tuned trucks, and fits all models, including Cab & Chassis.
- Cold Air Intake: While the 6.7L’s factory airbox is decent, an aftermarket Cold Air Intake for 2011-2016 6.7L with a high-flow dry filter can reduce restriction and provide cooler intake air, supporting the increased airflow demands of other mods.
- High-Flow Downpipe (For Later Models): For 2015-2019 and 2020-2024 trucks, upgrading the restrictive factory downpipe is a significant bottleneck-remover. Installing a 4" High-Flow Downpipe for 2015-2019 or for 2020-2024 allows the turbos to expel exhaust gas much more efficiently, reducing backpressure right at the source and improving turbo response.
- Tonneau Covers: Protecting your cargo bed is essential. Accurate bed length measurement is the first step.For Super Duty trucks, common sizes are 8ft (long bed) and 6.8ft (standard bed).
- For 2017-2025 Super Duty with an 8ft bed: Use the 8ft Soft Roll-Up Cover (2017-2025).
- For 1999-2016 Super Duty with an 8ft bed: Use the 8ft Soft Roll-Up Cover (1999-2016).
- For a more secure option, a Hard Tri-Fold Cover is available for both 8.2ft and 6.8ft beds.
- Towing & Recovery Enhancements:
- Adjustable Drop Hitch: For level towing with various trailers, a Heavy-Duty Adjustable Drop Hitch is invaluable, offering a 6-inch drop/rise range and anti-theft security.
- Heavy-Duty Ball Mount with Recovery Point: The Forged Steel Towing Ball Mount with D-Ring combines a 2-inch ball with a massive 3/4” D-ring shackle, making it perfect for both towing and as a secure rear recovery point.
- Kinetic Recovery Rope: For safe vehicle recovery, a 1” x 30ft Kinetic Recovery Rope Kit is far superior to a static strap, absorbing shock loads to protect both vehicles.
