How Much Can a 3" DPF Delete Pipe Improve a 2020-2024 RAM Ecodiesel? A Technical Look
I've been following the 3.0L Ecodiesel since it first appeared in the RAM 1500. It's an intriguing engine—a compact, Italian-designed V6 diesel that delivers respectable torque and impressive fuel economy in a half-ton package. The 2020-2024 models, in particular, benefitted from several updates that improved reliability over the earlier Gen 2 engines.
But like every modern diesel, the Ecodiesel carries emissions equipment that introduces compromises. At the center of that system sits the Diesel Particulate Filter—a component that, while effective at trapping soot, creates backpressure, consumes fuel during regeneration, and carries a finite service life.
I've been researching DPF delete options for the Ecodiesel, and recently had the chance to work with the TruckTok 3" delete pipe. Here's what I learned about why this modification matters on this engine and what it actually delivers.
Part 1: What the DPF Actually Does to Your Ecodiesel​
Before we talk about removing it, let's understand what the DPF does and what it costs you.
The soot trap: The DPF is a ceramic wall-flow filter that traps particulate matter from the exhaust. Soot accumulates in the filter, and when it reaches a certain load, the engine initiates a regeneration cycle—injecting raw fuel late in the combustion stroke to raise exhaust temperatures and burn off the trapped soot.
The backpressure penalty: Every filter creates restriction. The DPF forces exhaust gas through porous ceramic walls, which creates backpressure that the engine must overcome. Higher backpressure means the turbo works harder, exhaust gas temperatures rise, and the engine expends energy pushing exhaust out rather than turning the wheels.
The fuel penalty: Regeneration cycles consume fuel that doesn't contribute to propulsion. During a regen, the engine is burning diesel to clean a filter, not to move the truck. Over time, this adds up to a measurable fuel economy loss.
The ash problem: Soot burns. Ash doesn't. Ash is the non-combustible residue from engine oil additives, and it accumulates in the DPF permanently. Eventually—typically around 150,000-200,000 miles—the ash load becomes significant enough to require DPF cleaning or replacement. That's a $1,500-$3,000 expense waiting to happen.
Part 2: What Makes the Ecodiesel's DPF Situation Unique​
The 3.0L Ecodiesel has some specific characteristics that affect how the DPF system performs.
Regeneration frequency: Ecodiesel owners report varying regeneration intervals depending on driving patterns. Short trips and city driving can trigger more frequent regens, increasing the fuel penalty and putting more thermal cycles on the DPF.
The packaging: The Ecodiesel is shoehorned into the RAM 1500's engine bay, and the emissions equipment is tightly packaged. Servicing the DPF requires significant labor if it ever needs replacement.
The oil dilution concern: Some Ecodiesel owners have noted fuel dilution in engine oil related to regeneration cycles. While later model years improved on this, the fundamental physics remain—post-injected fuel can make its way past the rings and into the crankcase.
Part 3: What the TruckTok 3" Delete Pipe Does​
The TruckTok kit replaces the factory DPF assembly with a straight-through 3-inch pipe. Here's what's included and why it matters.
3-inch diameter: The 3-inch size is well-matched to the Ecodiesel's displacement and flow requirements. It provides a significant reduction in backpressure compared to the restrictive factory DPF while maintaining exhaust velocity for good turbo response.
409 stainless steel construction: T-409 stainless offers excellent corrosion resistance and durability at a reasonable cost. It's the ideal material for exhaust components that need to withstand high temperatures and road salt exposure.
Complete hardware: The kit includes four pipes, three clamps, a gasket, and four bolts. Everything you need for installation is in the box—no hunting for missing parts.
The flow improvement: With the DPF removed, exhaust gases flow freely from the turbo outlet to the tailpipe. No more forcing exhaust through a ceramic filter. No more backpressure fighting the turbo.
Part 4: What You Gain by Removing the DPF​
When paired with proper tuning, DPF deletion on the Ecodiesel delivers several measurable improvements.
Increased power and torque: The product notes that DPF delete, combined with an ECU remap, increases power and torque. This is accurate because the engine no longer has to overcome the restriction of the DPF. Less backpressure means the turbo spools faster and maintains boost more effectively.
Improved fuel economy: With no fuel-wasting regeneration cycles and reduced pumping losses, fuel economy improves. Owners typically report gains of 2-4 MPG depending on driving conditions.
Lower exhaust gas temperatures: Reduced backpressure means the engine expends less energy pushing exhaust out, which translates to lower EGTs under load. This is particularly beneficial for towing applications where thermal management is critical.
Elimination of DPF maintenance: There is no maintenance. No cleaning, no replacement, no worrying about ash accumulation at 150,000 miles.
Removal of failure risk: DPFs can fail. They can crack, they can clog irreversibly, they can cause backpressure issues that damage the turbo. Removing the DPF eliminates this entire category of potential failure.
Part 5: The Tuning Imperative​
The product information mentions that the delete pipe should be "paired with an ECU remap." This is not optional.
The Ecodiesel's ECM is programmed to monitor DPF operation—differential pressure, exhaust temperatures, soot load models. When it detects that the DPF is missing, it will set codes, illuminate the check engine light, and likely initiate a power derate.
A proper delete tune does three things:
  • Disables DPF regeneration logic
  • Eliminates fault codes for missing components
  • Optimizes fuel delivery for the new exhaust flow
Without tuning, the hardware alone won't make the truck run properly.
Part 6: The Installation Reality​
The product notes "easy, fast installation." For someone comfortable with exhaust work, this is accurate. The kit is designed as a direct replacement for the factory DPF assembly.
The factory DPF is heavy and awkward, but with the truck properly supported, removal is straightforward. The new pipes bolt in using the existing mounting points. The included clamps and gasket ensure leak-free connections.
Installation time is typically 2-3 hours for a DIYer with basic tools.
Part 7: The Fitment Details​
This kit fits: 2020-2024 RAM 1500 with the 3.0L Ecodiesel
Important note: It does NOT fit Jeep Grand Cherokee Ecodiesel models, which have different exhaust routing.
The kit is designed for pickup applications and won't work on the SUV variants.
Part 8: The Verdict​
The 2020-2024 RAM Ecodiesel is a capable and efficient engine that's well-suited to half-ton truck duties. But like all modern diesels, its DPF system introduces compromises—backpressure, regeneration fuel penalties, and a component with a finite service life.
The TruckTok 3" DPF Delete Race Exhaust Pipe addresses these compromises directly. It replaces the restrictive factory DPF with a free-flowing 3-inch pipe, reducing backpressure, improving turbo response, and eliminating regeneration cycles. When paired with proper tuning, it unlocks power, torque, and fuel economy that the factory system leaves on the table.
For Ecodiesel owners who plan to keep their trucks long-term and want to eliminate a potential failure point, this kit makes technical sense. It's not about making the truck louder or smoking—it's about efficiency, reliability, and letting the engine breathe the way it should.
If you've deleted the DPF on your Ecodiesel, what was your experience with fuel economy gains and tuning? Drop your thoughts below.
