If you’ve spent any time in Duramax forums, you’ve seen the debate. Some guys swear you can just tune the EGR off and call it a day. Others insist you need to pull the whole system and throw it in the scrap bin. I spent two years in the “tune‑only” camp. My LMM ran fine. No codes, no smoke, no surging. The EGR valve stayed shut, and the cooler sat there doing absolutely nothing.
So why did I spend a Saturday afternoon installing a full EGR delete kit?
Because “doing nothing” isn’t the same as “eliminating the risk.” That cooler might not be flowing exhaust, but it’s still full of coolant, still bolted to the engine, and still one hairline crack away from pressurizing your cooling system or hydrolocking a cylinder. The valve might be closed, but it’s still taking up space, adding weight, and collecting grime.
I decided to pull it all—cooler, valve, feed pipe, and that restrictive plastic intake elbow. I used the TruckTok 2007-2010 LMM EGR Delete Kit, which replaces every emissions component with purpose‑built aluminum and stainless hardware. Here’s what the process actually involves, what you gain, and whether the extra effort is worth it for your truck.
What software disable cannot do:
The U‑Shaped Black Coolant Tube
This is the heart of the cooling system modification. The factory EGR cooler has an inlet and outlet coolant hose. Once the cooler is removed, those two hoses need to be connected to maintain a sealed, functional cooling system. This pre‑bent, powder‑coated tube does exactly that. No cutting, no splicing, no leaking. The constant‑tension hose clamps are included and actually seal.
The Exhaust Block‑Off Plate
CNC‑cut stainless steel, not cheap mild steel that will rust through in two winters. It bolts directly to the exhaust manifold where the EGR feed pipe originally connected. The fitment is precise—no filing, no grinding. A thin smear of high‑temp RTV ensures a perfect seal.
The High‑Flow Intake Elbow
This is the bonus upgrade you don’t expect. The factory LMM intake elbow is plastic, has a tight radius, and includes a resonator chamber that disrupts airflow. This replacement is cast aluminum, mandrel‑bent, and polished. The internal bore is smooth and unobstructed. Even if you weren’t deleting the EGR, this elbow alone improves throttle response and reduces intake air temperatures.
All Necessary Hardware
Bolts, cap heads, flange nuts, O‑ring, and clamps—everything is included. No last‑minute trips to the hardware store. No mixing and matching thread pitches.
This was the most immediate and measurable difference. Pre‑delete, my LMM’s coolant temp would climb to 210°F in stop‑and‑go traffic with the AC running. Post‑delete, it stabilizes at 195°F and stays there regardless of conditions. Removing the EGR cooler eliminates a significant restriction and a constant heat load from the cooling system.
Intake Air Temperatures
The aluminum elbow does not soak heat like the factory plastic unit. IAT2 readings are noticeably lower and recover faster after hard acceleration.
Engine Bay Cleanliness
This is subjective, but satisfying. The valley between the heads is now empty. No cooler, no valve, no tangled vacuum lines. Access to the turbo pedestal and fuel filter housing is dramatically improved.
Throttle Response
Not a night‑and‑day transformation, but a distinct sharpness that wasn’t there before. The combination of unrestricted intake airflow and the complete absence of exhaust gas anywhere near the inlet track makes the engine feel more eager.
Weight Reduction
The factory EGR cooler and valve assembly weighs approximately 15 pounds. It’s not going to change your 0‑60 time, but it’s 15 pounds of unnecessary cast iron removed from the top of the engine.
If you install this kit and fire up the truck with a factory calibration, three things will happen immediately:
Important compatibility note: ECM operating systems vary between 2007.5, 2008, 2009, and 2010 trucks. Confirm with your tuner that your specific OS is supported before you begin.
It is not the cheapest way to stop exhaust gas recirculation. A tune alone accomplishes that for the cost of a few hundred dollars and zero knuckle scraping.
What this kit offers is permanence. It removes the cooler that can fail, the valve that can stick, and the heat load that raises coolant temperatures. It replaces a restrictive plastic intake elbow with a free‑flowing aluminum casting. It cleans up the engine bay and eliminates a decade of accumulated grime traps.
If you are already committed to a full emissions delete, or if your EGR cooler is living on borrowed time, this is the complete, bolt‑in solution. Everything you need is in the box. The only additional requirements are a few hours of your time, a penetrating oil budget, and a tuner who knows how to properly disable the EGR system.
If you’ve installed a full EGR delete on your LMM, what was your experience with the manifold bolts? Did you notice a difference in coolant temperatures? Drop your story below.
Part 1: Why Software Disable Isn’t the Same as Hardware Removal
Let’s be absolutely clear: a properly tuned software disable stops exhaust gas from recirculating. The valve stays shut. Your intake manifold won’t fill with carbon. The truck will run cleanly for tens of thousands of miles.What software disable cannot do:
- Eliminate the EGR cooler as a failure point. Even with zero exhaust flow, the cooler is still a heat exchanger filled with engine coolant. It has endured hundreds of thermal cycles since 2007. The internal core can crack at any time—tuning doesn’t prevent metallurgical fatigue. If that happens, coolant enters the intake or exhaust, and you’re looking at a tow bill and a very expensive repair.
- Remove a significant heat source from your cooling system. The EGR cooler sits in the engine valley, constantly radiating heat into the coolant. Removing it lowers overall coolant temperatures and reduces strain on the water pump and radiator.
- Clean up the engine bay. The cooler, valve, feed pipe, and associated vacuum lines occupy valuable real estate. Deleting them improves access to the turbo pedestal, fuel filter housing, and transmission dipstick.
- Prevent future maintenance. What happens if the next owner flashes a stock tune back into the ECM? That closed valve suddenly becomes active again, and a decade of carbon deposits can cause it to stick or fail.
Part 2: What’s Actually in the Box – A Complete Replacement System
I’ve installed EGR delete kits that were nothing more than a stamped steel plate and a ziplock bag of bolts. The TruckTok LMM kit is not that. It replaces every component that gets removed, using materials that outlast the factory parts.The U‑Shaped Black Coolant Tube
Part 3: The Tangible Results – What Actually Changes
Coolant TemperaturesThis was the most immediate and measurable difference. Pre‑delete, my LMM’s coolant temp would climb to 210°F in stop‑and‑go traffic with the AC running. Post‑delete, it stabilizes at 195°F and stays there regardless of conditions. Removing the EGR cooler eliminates a significant restriction and a constant heat load from the cooling system.
Throttle Response
Weight Reduction
Part 4: The Tuning Requirement – Non‑Negotiable
This kit removes the hardware. It does not remove the software dependency.If you install this kit and fire up the truck with a factory calibration, three things will happen immediately:
- The check engine light will illuminate. P0401, P0404, or P0405—sometimes all three.
- The ECM will attempt to actuate an EGR valve that no longer exists. This can cause erratic idle, reduced power, or transmission shift anomalies.
- The truck may enter limp mode.
- Zeroes all EGR desired flow tables
- Raises EGR enable temperature thresholds to values the engine will never reach
- Leaves B1501 (EGR System Enable) in its factory ENABLED state—never set this parameter to Disable
Part 5: Who Should Buy This Kit?
You are the ideal candidate if:- You are already deleting the DPF. The exhaust system is coming apart, the truck is on stands, and you’re already under the chassis. Adding the EGR delete at the same time adds approximately one hour of labor.
- Your EGR cooler is original and you plan to keep the truck beyond 200,000 miles. This is preventative maintenance. The cooler will not fail if it is not there.
- You have experienced coolant loss, white steam, or a sweet exhaust smell. Those are symptoms of a failing EGR cooler. Replace it with a delete kit before it fails catastrophically.
- You value simplicity and serviceability. An empty engine valley is easier to work on than one cluttered with emissions equipment.
- Your truck must pass visual emissions inspections. In California, New York, Colorado, Maine, and other states that follow CARB rules, a missing EGR cooler is an automatic failure. There is no legal way to register a vehicle with these components removed.
- You are not prepared to deal with seized exhaust fasteners. Broken manifold bolts are a real risk. If you do not have extractors, a torch, or the patience to drill out hardened steel, this job can become a nightmare.
- You simply want to stop exhaust gas recirculation. A properly configured tune achieves that goal with zero hardware changes and zero risk of broken bolts.
Part 6: Fitment – Verify Before You Order
This kit is specifically engineered for:- 2007.5 – 2010 Chevrolet Silverado 2500HD / 3500HD
- 2007.5 – 2010 GMC Sierra 2500HD / 3500HD
- Equipped with the 6.6L LMM Duramax diesel (VIN code 7)
- 2001–2007 LB7, LLY, or LBZ engines
- 2011+ LML or L5P engines
- Cab and chassis trucks
- Gasoline engines
The Bottom Line
The 2007.5–2010 LMM Duramax occupies a unique position in diesel history. It is the last generation that can be fully, physically deleted of EGR hardware without requiring complex sensor retention tricks or ECM bench unlocking. The TruckTok EGR Delete Kit takes full advantage of that simplicity.It is not the cheapest way to stop exhaust gas recirculation. A tune alone accomplishes that for the cost of a few hundred dollars and zero knuckle scraping.
