Owning a 2017-2023 L5P Duramax means you have one of the most powerful stock diesel pickups ever built. But beneath that impressive power lies a familiar engineering compromise. While the DPF gets most of the attention for strangling exhaust flow, two other factory systems are quietly working against your engine's long-term health: the Exhaust Gas Recirculation (EGR) and Crankcase Ventilation (CCV) systems.
This guide isn't about chasing peak dyno numbers. It's about preventative medicine for your engine. We're going to dissect how these systems, designed for emissions compliance, actively contaminate and stress your L5P. More importantly, we'll provide a clear, step-by-step plan for surgically removing these liabilities, focusing on reliability, cleanliness, and preserving your truck's performance for the long haul.
1. The EGR System: The Mandated Soot Recycler.
The Exhaust Gas Recirculation system's job is to lower combustion temperatures (and thus NOx emissions) by recirculating inert exhaust gas back into the intake manifold. This gas is first cooled by the EGR Cooler.
The Closed Crankcase Ventilation system manages blow-by gases (vapors that slip past the piston rings). In its stock form, the L5P's system routes these oily, fuel-diluted vapors from the valve cover back into the turbo inlet pipe.
EGR Delete Core Benefits:
For the EGR System: Complete Cooler & Valve Removal.
The goal is total removal of the entire assembly and proper management of the open coolant passages. This requires a comprehensive kit.
The TruckTok EGR Valve & Cooler Delete Kit for the L5P is engineered for this complete procedure. As the description notes, it includes high-quality billet aluminum and stainless-steel block-off plates, along with the necessary high-temperature silicone hoses and fittings to properly seal or reroute the coolant lines. This ensures your cooling system remains sealed and efficient after the cooler is gone. It's a complete solution that removes the soot source and the coolant leak risk simultaneously.
For the CCV System: A Clean, Efficient Reroute.
The goal is to redirect crankcase vapors away from the intake tract entirely and upgrade the failure-prone factory parts.
The TruckTok CCV Reroute/Delete Kit for the L5P (note the product title indicates 2017-2024 fitment) is designed as a smart upgrade. It replaces the plastic factory assembly with an aluminum unit that often incorporates beneficial features like internal baffling or "drop devices" to separate oil from vapor more effectively. It includes new, durable hosing to reroute these clean vapors to a safe vent location (like a catch can or a filtered vent), keeping oil out of your intake and upgrading a known weak component in one step.
This is critical and cannot be skipped. The L5P's Engine Control Unit is programmed to actively monitor and control the EGR system. Removing it without disabling its function in the software will cause persistent fault codes, a check engine light, and a debilitating limp mode. A proper custom tune disables all EGR monitoring and adjusts engine parameters to run optimally without it. Source your tuning solution from a reputable, L5P-specific tuner before you begin the physical install.
4.2 Installation Overview: A Methodical Approach.
A: While physically possible, it is highly inefficient and illogical. The custom tuning required to properly disable the EGR system is almost always part of a comprehensive "delete" tune that also handles the DPF and SCR systems. Furthermore, the performance and reliability benefits are maximized when all restrictive emissions systems are addressed together.
Q2: Will I see a fuel economy increase from just the EGR/CCV mods?
A: The massive fuel economy gains come primarily from disabling the DPF and its constant regeneration cycles. The EGR delete contributes to sustained efficiency by preventing the carbon buildup that gradually harms combustion efficiency over tens of thousands of miles. The CCV reroute helps maintain optimal intake air temperatures, supporting performance.
Q3: Where should I route the CCV vent hose?
A: The two most common and responsible methods are:
1. To a Quality Catch Can: This is the best practice. The can condenses and collects oil vapors, allowing clean air to vent. You empty the can periodically.
2. To a Filtered Vent ("Breather"): Route the hose down to a small filter mounted low on the frame. This vents to atmosphere but contains any minimal oil mist in the filter element.
Simply routing an open hose to the ground is messy, environmentally questionable, and may be illegal in your area.
Q4: What about the "improved coolant flow" mentioned in the EGR kit description?
A: This is a legitimate secondary benefit. The factory EGR cooler is a restrictive element in the coolant circuit. Removing it and properly capping the lines can, in some designs, improve overall coolant flow and reduce the workload on the water pump, contributing to marginally better cooling system efficiency.
Q5: What is the legal status of these modifications?
A: Compliance Disclaimer: For vehicles registered for on-road use in the United States, tampering with or removing the EGR system—a federally mandated emissions control device—is a violation of the Clean Air Act. The components discussed are marketed and sold for off-road and competition use only. The vehicle owner is solely responsible for understanding and complying with all applicable local, state, and federal regulations.
By selecting a complete EGR delete kit, pairing it with an intelligent CCV reroute solution, and supporting both with professional, L5P-specific custom tuning, you are fundamentally investing in the durability and cleanliness of your engine. The result is a truck that not only performs well today but is also built to deliver that performance reliably for many miles to come.
Part 1: Diagnosis - The Factory-Engineered Contaminants
The L5P is a masterpiece of power and technology, but it still adheres to federal emissions mandates that prioritize tailpipe cleanliness over internal engine cleanliness. Understanding this conflict is key.1. The EGR System: The Mandated Soot Recycler.
- The Guaranteed Damage: Carbon Buildup. You are literally piping dirty, soot-laden exhaust back into your engine's clean air intake. This causes heavy carbon deposits to form on intake valves, inside the manifold, and on the EGR valve itself. This is not a maybe; it's an inevitability. Over time, this buildup robs power, hurts fuel efficiency, and can lead to rough idles and costly cleanings.
- The Catastrophic Risk: Cooler Failure. The EGR cooler is a pressurized heat exchanger under constant thermal stress. It is a documented failure point across all modern diesels. When its internal core cracks, it leaks engine coolant directly into the intake manifold. This can lead to coolant ingestion into the cylinders, resulting in hydrostatic lock (hydrolock), which can bend connecting rods or necessitate a complete engine replacement—a financial catastrophe.
- The Insidious Effect: Intercooler and Turbo Fouling. This oil mist coats the turbo compressor wheel and, most critically, the fins of the intercooler. Over tens of thousands of miles, this reduces the intercooler's ability to cool the intake charge, leading to higher intake air temperatures (IATs), reduced performance, and increased stress. It also creates a sticky film inside the intake that perfectly captures the dry soot from the EGR system.
- The L5P-Specific Weakness: The factory plastic CCV assembly itself is prone to cracking and failure over time, especially with heat cycling, creating another vacuum leak or oiling issue to diagnose.
Part 2: The Cure - Systemic Benefits of Correction
Addressing these systems is not a "performance mod" in the traditional sense. It is corrective maintenance that restores the engine to a rational, clean-operating state. The benefits are profound and preventative.EGR Delete Core Benefits:
- Eliminates Intake Carbonization: Your intake ports, valves, and manifold stay factory-clean. This preserves optimal airflow, combustion efficiency, and power output for the life of the engine.
- Removes a Catastrophic Failure Point: Deleting the EGR cooler completely eradicates the risk of coolant-induced hydrolock. This is the single greatest reliability improvement you can make to any modern diesel.
- Reduces Engine Operating Temperatures: Coolant is no longer superheated by exhaust gases in the EGR cooler, and hot exhaust is no longer added to the intake charge. This contributes to lower overall coolant and intake air temps.
- Simplifies the Engine Bay: Removes a complex assembly of valves, coolers, and sensors that are prone to failure.
- Preserves Charge Air System Cleanliness: Stops oil vapor from contaminating and coating the turbo compressor and intercooler core. This maintains peak intercooler efficiency and prevents the associated power loss from high IATs.
- Eliminates a Plastic Failure Point: Replaces the prone-to-crack factory plastic CCV assembly with a durable, often metal, aftermarket solution.
- Promotes Cleaner Engine Oil: By venting blow-by vapors away instead of recirculating them, you reduce the rate of oil dilution and contamination.
- Complements the EGR Delete Perfectly: With the EGR's soot gone and the CCV's oil mist redirected, your engine's intake tract remains truly clean.
Part 3: The Treatment Plan - Component Solutions for the L5P
For a permanent, reliable solution, you need kits designed specifically for the L5P's unique layout. Half-measures like "plate-only" EGR deletes that leave the cooler in place are unsafe and incomplete.For the EGR System: Complete Cooler & Valve Removal.
Part 4: Surgical Procedure - Installation & The Tuning Imperative
4.1 The Non-Negotiable Pre-Op: Custom ECU Tuning (for EGR).This is critical and cannot be skipped. The L5P's Engine Control Unit is programmed to actively monitor and control the EGR system. Removing it without disabling its function in the software will cause persistent fault codes, a check engine light, and a debilitating limp mode. A proper custom tune disables all EGR monitoring and adjusts engine parameters to run optimally without it. Source your tuning solution from a reputable, L5P-specific tuner before you begin the physical install.
- EGR Delete (Moderate Difficulty):This is a 4-8 hour job requiring mechanical competence.
- Prep: Disconnect the battery. Drain a portion of the engine coolant into a clean pan. Soak the exhaust manifold nuts/studs for the EGR pipe with a quality penetrating oil overnight.
- Process: Follow the kit instructions meticulously. You will disconnect coolant hoses, electrical connectors, and unbolt the EGR assembly from the intake and exhaust manifold. Install the block-off plates and coolant line caps/plugs as directed.
- Post-Install: Refill coolant with the proper Dex-Cool mix, bleed the cooling system of air, and inspect thoroughly for leaks before restarting.
- CCV Reroute (Easy to Moderate): This is a simpler 1-2 hour job. It involves removing the factory CCV parts, installing the new aftermarket block/fitting on the valve cover, and routing the new hose to its designated location (e.g., to a catch can or a filtered vent positioned down low).
- Tools & Safety: A full metric socket set with extensions and swivel joints is essential. Safety glasses, gloves, and shop towels are recommended. Torque all fasteners to specification and always use new gaskets where provided.
Part 5: Post-Op Recovery & FAQ
Q1: Can I do just the EGR/CCV mods and leave the DPF/SCR system alone?A: While physically possible, it is highly inefficient and illogical. The custom tuning required to properly disable the EGR system is almost always part of a comprehensive "delete" tune that also handles the DPF and SCR systems. Furthermore, the performance and reliability benefits are maximized when all restrictive emissions systems are addressed together.
Final Prognosis: A Healthier, Longer-Lived L5P
Investing in an EGR delete and CCV reroute for your L5P Duramax is a definitive step toward long-term ownership satisfaction. You are not adding complexity or strain; you are removing it. You are proactively eliminating a known catastrophic failure mode and stopping a guaranteed process of internal engine contamination.By selecting a complete EGR delete kit, pairing it with an intelligent CCV reroute solution, and supporting both with professional, L5P-specific custom tuning, you are fundamentally investing in the durability and cleanliness of your engine. The result is a truck that not only performs well today but is also built to deliver that performance reliably for many miles to come.
