What’s up, everyone?
Since its debut in 2011, the Ford-designed 6.7L Powerstroke has proven itself to be a monster. It’s lightyears ahead of the 6.0 and 6.4 in terms of reliability and stock power. However, as these trucks age—or as we start asking more from them in competition and heavy towing—the factory exhaust system becomes a massive bottleneck.
The 6.7L "Scorpion" engine is capable of incredible things, but it’s essentially wearing a gas mask and a heavy winter coat. I’ve spent the last decade tuning and tweaking these trucks, and today I want to break down how to properly open up the exhaust path to reduce heat, increase longevity, and finally hear that turbo whistle.
1. The Backpressure IssueThe stock exhaust is designed to trap soot. Over time, that DPF gets clogged. Your truck then enters "Active Regeneration," where it dumps extra fuel into the exhaust to burn that soot off. This creates massive backpressure, which is the enemy of your turbocharger’s thrust bearings.
2. The EGT ProblemWhen the truck is in regen, Exhaust Gas Temperatures (EGTs) can skyrocket. Constant high-heat cycles are what lead to dropped valves or cracked manifold bolts.
3. The DEF HeadacheThe SCR system relies on Diesel Exhaust Fluid (DEF). Between frozen heaters, failed pumps, and the dreaded "50 miles to 5 MPH" limp mode, the complexity of the stock exhaust is often what leaves 6.7L owners stranded—not the engine itself.
Q: Is it too loud for daily driving?A: The 4" systems are very manageable. The 5" straight-pipe is definitely loud. If you’re worried about drone while towing, you can always add a high-flow muffler to these kits later.
Q: What about the law?A: Legal Notice: These exhaust modifications involve removing emissions control devices and are intended strictly for off-road, competition, or exhibition use only. Operating a vehicle with these parts on public roads is a violation of the Clean Air Act in the U.S. and can result in significant fines. Always check your local and state emissions laws before modifying your vehicle.
Stop letting your engine choke on its own exhaust. Get that backpressure down and enjoy the ride!
What’s your setup? Are you a 4-inch or 5-inch fan? Let me know in the comments below!
Part 1: The Factory "Chokehold" (Why Mod?)
The 2011-2022 trucks are loaded with emissions hardware: the Diesel Oxidation Catalyst (DOC), the Selective Catalytic Reduction (SCR), and the Diesel Particulate Filter (DPF).1. The Backpressure IssueThe stock exhaust is designed to trap soot. Over time, that DPF gets clogged. Your truck then enters "Active Regeneration," where it dumps extra fuel into the exhaust to burn that soot off. This creates massive backpressure, which is the enemy of your turbocharger’s thrust bearings.
Part 2: Choosing Your Performance Path
When you're ready to move to a competition-style setup, you need to decide how much of the system you want to replace. I’ve had great luck with TruckTok components lately because they use T-409 stainless steel, which handles the "salt belt" winters much better than cheaper aluminized pipes.Step 1: The Turbo Exit (Downpipes)
The factory downpipe is often "pancaked" or cramped to fit the firewall. Replacing this is the first step to lowering EGTs right at the source.- For 2015-2019 Models: I recommend the high-flow 4" stainless downpipe. It clears out the turbine discharge much more efficiently than the stock unit.
- For 2020-2024 Models: Ford updated the turbo setup slightly, so make sure you grab the specifically engineered 2020+ downpipe. The improved geometry here significantly helps with throttle response and "spool-up" time.
Step 2: The Mid-Section (Delete Pipes)
If you are looking for a simple, effective way to remove the DPF/CAT restriction for race applications, you have a few solid options:- The Stealth/Straight Swap: You can go with a 4" DPF & Cat delete pipe kit. This is a direct replacement for the heavy factory canisters. It eliminates the possibility of a DPF failure and stops those expensive engine repairs caused by backpressure.
- The "Race Ready" 4-Inch: For those doing a full "Downpipe-Back" setup, the 4" DP-Back race exhaust provides maximum flow without the bulk of a muffler. It’s loud, aggressive, and incredibly efficient.
- The "Big Bore" 5-Inch: If you are chasing high horsepower or just want that deep, guttural "big rig" sound, I’d suggest the 5-inch downpipe-back delete pipe. The 5" diameter offers the lowest possible backpressure and a tone that you just can't get from a 4" system.
Part 3: The Install – Tips from the Trenches
Installing these on a 6.7L is actually easier than on the older 6.4L, but there are a few "gotchas":- The Sensors: There are several EGT and NOx sensors plugged into the stock exhaust. You’ll need a 22mm wrench (and likely some heat) to get them out if you plan on reusing them. If you’re using a race tuner, you won’t need them, but you should zip-tie the harnesses out of the way so they don't melt.
- The Downpipe Clamp: The V-band clamp at the turbo is notoriously stubborn. Do not force it or you’ll strip the nut. Use a long extension and hit it with penetrating oil first.
- Hanger Alignment: Most of the TruckTok kits come with OEM-style hangers. I recommend soaping up the rubber isolators before you try to slide the new 4" or 5" hangers in. It makes life 10x easier.
Part 4: Post-Mod Feelings
After dropping the weight of the factory emissions (that DPF assembly weighs a ton!), the truck feels like a different animal.- Fuel Economy: Expect to see a 2-4 MPG increase on the highway.
- Engine Noise: You’ll finally hear the variable geometry turbo (VGT) "hiss" at idle and scream at full throttle.
- Throttle Response: The "lag" when you step on it is almost entirely gone. The turbo doesn't have to fight a wall of soot to get the exhaust out.
Part 5: Common Questions & Legal Realities
Q: Do I need a tune?A: YES. You cannot simply bolt on a delete pipe and drive. The truck’s computer will see that the DPF pressure hasn't changed and will put the truck into "Limp Mode" immediately. You need a tuner to calibrate the ECU for the new flow.Q: Is it too loud for daily driving?A: The 4" systems are very manageable. The 5" straight-pipe is definitely loud. If you’re worried about drone while towing, you can always add a high-flow muffler to these kits later.
Conclusion
The 6.7L Powerstroke is a legend in the making, but it deserves to breathe. Whether you go with a 4-inch DPF delete for a cleaner engine or a full 5-inch race system for maximum power, you’re making an investment in the efficiency of your truck.Stop letting your engine choke on its own exhaust. Get that backpressure down and enjoy the ride!
