I've had my 2003 Silverado 2500HD Crew Cab for about eight years now, and it's been through everything. Hauling equipment, pulling trailers, job sites, hunting trips—the usual stuff that makes these GMT800 trucks legendary. They're simple, reliable, and they just keep going.
But the interiors? They show their age faster than anything else.
These trucks are 20-plus years old now. Even if the body and engine are in great shape, the carpet often tells a different story. Stains that won't come out. Worn spots where heels have ground in dirt. Salt lines along the edges from winters past.
I went through a few sets of floor mats over the years. Cheap rubber mats that curled up and slid around. Universal mats that never quite fit. Nothing really worked until I switched to Trucktok Silverado Sierra 1999-2006 Silverado/Sierra 1500 2500 3500 Crew Cab All-Weather TPE Floor Mats.
Here's what I learned about protecting these old Chevys.
The Problem with Factory Carpet in an Older Truck
The GMT800 trucks have decent carpet from the factory. It's not luxury car stuff, but it does the job. The problem is that carpet in a work truck has a short lifespan.
Every time you get in with muddy boots, that dirt grinds into the fibers. Snow melts and soaks in. Road salt eats away at the backing. Coffee spills leave permanent marks.
Once carpet is stained, there's no good fix. You can clean it, but you'll never get it back to new. The fibers mat down permanently. The stains set in. And replacing carpet in a Crew Cab is a massive job involving seat removal and hours of labor.
The smart move isn't trying to keep the carpet clean forever. It's putting something between your boots and that carpet that actually works.
Why TPE Makes Sense for an Older Truck
Most people think rubber when they think of heavy-duty floor mats. And rubber works, sort of. But it has problems that show up over time.
Rubber mats smell. Leave your truck in the sun and come back to that chemical odor filling the cab. In an older truck that might already have some mustiness, you don't need that.
Rubber gets stiff in cold weather. Try pulling out a frozen rubber mat sometime.
Rubber can crack and warp over time. Years of temperature cycles take their toll.
TPE is different. There's no odor, even after hours in direct sun. It stays flexible from below freezing to hot summer days. It doesn't crack or warp with age. And it's lighter than rubber while being just as tough.
Why Fit Matters for Safety
Universal mats are a compromise, and sometimes a dangerous one. If a mat slides forward and gets under the pedals, you could have a serious problem. I've seen it happen.
These mats are laser-scanned specifically for the Crew Cab body style. Every contour matches the floor exactly. The transmission tunnel coverage is precise. The edges come up where they need to without interfering with anything.
They're compatible with the factory retention clips too. They lock into place and stay there. No sliding, no bunching, no shifting.
The critical clearance zones around the gas and brake pedals are engineered into the design. No interference, no worries.
What About Cleaning
This is the feature that sells most people. When these mats get dirty, you pull them out and hose them off.
Mud rinses away instantly. Salt dissolves and disappears. Coffee, oil, whatever—it all comes off with water.
Let them drip dry for a few minutes and put them back in. They look brand new every time. No scrubbing, no special cleaners, no hauling them to the car wash.
In a Crew Cab, that's three large mats to clean. Being able to just hose them off saves a ton of time.
Built to Last in the Sun
These trucks are often parked outside. They've spent decades in the sun. UV exposure takes its toll on everything.
These mats are infused with stabilizers to prevent sun damage and chalking over time. They won't fade or turn gray from UV exposure. They'll look good for as long as you own the truck.
Safe for People and Pets
These mats are free of lead, cadmium, and latex. If you've got kids climbing in and out, or dogs riding along, you don't have to worry about toxic materials.
They're eco-friendly and scent-free. No off-gassing, no chemical smell. Just a clean, safe interior.
The Crew Cab Specifics
These are made for the Crew Cab trucks from 1999-2006. That includes:
They won't fit Extended Cab or Regular Cab trucks. The floor shape is completely different.
What You Get
The set includes three pieces. Two for the front row—driver and passenger. One for the second row that covers the whole back floor area.
The front mats have raised edges to contain spills and debris. Everything you track in stays on the mat.
The rear mat is one continuous piece that protects the whole back area. In a Crew Cab, that's a lot of floor space. Having it fully covered means no dirt gets through to your carpet.
The Long-Term Value
These mats will outlast your truck. No cracking, no warping, no fading. The high-density TPE is thicker than standard rubber and built for years of abuse.
And when it comes time to sell, you can pull them out and reveal carpet that still looks new. For an older truck that's holding its value, that matters.
Final Thoughts
The GMT800 trucks are legends for a reason. They're simple, reliable, and still doing real work after 20-plus years. Keeping the interior clean is one of the best ways to preserve them.
TPE floor mats are the simplest solution. They fit perfectly, clean instantly, and last forever. No smell, no sliding, no staining. Just protection that works.
If you're tired of fighting mud and salt in your old Chevy, these mats are worth a look.
What do you use to protect your GMT800's interior? Drop your experience below.
What About Cleaning
- 1999-2006 Silverado/Sierra 1500 Crew Cabs
- 2007 Classic 1500 Crew Cabs
- 2001-2004 Silverado/Sierra 2500 and 3500 Crew Cabs
What You Get
The Long-Term Value
Final Thoughts
