I've had my 2011 F-150 SuperCab for about five years now, and it's been through everything. Job sites, hunting trips, hauling materials, towing trailers—the usual stuff that trucks do. And through all of it, the one thing that's taken the most abuse isn't the engine or the suspension. It's the interior floor.
These 12th-gen F-150s are great trucks. They're comfortable, reliable, and still look good today. But the factory carpet? Not so much after years of abuse. Once salt stains set in, they never really come out. Mud gets ground into the fibers. Spills leave permanent marks.
I tried cheap mats. I tried universal mats. Nothing really worked until I switched to Trucktok 2009-2014 Ford F150 SuperCab All-Weather TPE Floor Mats. Here's what I learned about keeping a truck clean without spending hours scrubbing.
The Problem with Factory Carpet
The 2009-2014 F-150s have decent carpet from the factory. It looks good when it's new. But carpet in a truck that actually gets used has a short lifespan.
Every time you get in with muddy boots, that dirt grinds into the fibers. Snow melts and soaks in before you even notice. Coffee spills, oil from equipment, dust from job sites—it all ends up ground into the carpet.
Once carpet is stained, there's no good fix. You can clean it, but you'll never get it back to new. The fibers mat down permanently. The stains set in. And replacing carpet is a huge job involving seat removal and hours of work.
The smart move isn't trying to keep the carpet clean forever. It's putting something between your boots and that carpet that actually works.
Why TPE Beats Rubber
Most people think rubber when they think of heavy-duty floor mats. And rubber works, sort of. But it has problems.
Rubber mats smell. Leave your truck in the sun and come back to that chemical odor. It's not harmful, but it's unpleasant.
Rubber gets stiff in cold weather. Try pulling out a frozen rubber mat sometime.
Rubber can crack and warp over time. Years of temperature cycles take their toll.
TPE is different. There's no scent, even after hours in direct sun. It stays flexible from way below freezing to hot summer days. It doesn't crack or warp with age. And it's lighter than rubber while being just as tough.
The Temperature Range is Real
These mats are tested from -58°F to 167°F. That's a huge range.
At -58, most materials get brittle. These stay flexible. You can pull them out to clean them without them cracking.
At 167, which is what a dark interior can hit in summer, they don't get soft or smell. They just sit there doing their job.
Why the Fit Matters
Universal mats are a compromise, and sometimes a dangerous one. If a mat slides forward and gets under the pedals, you could have a serious problem.
These mats are made specifically for the SuperCab. Every contour matches the floor exactly. They extend all the way to the door sills, so debris can't sneak around the edges and get onto your carpet.
The transmission tunnel coverage is precise. The pedal areas are clear. Nothing slides around because everything fits perfectly.
What About Cleaning
This is the best part. When these mats get dirty, you pull them out and hose them off. That's it.
Mud rinses away instantly. Salt dissolves and disappears. Coffee, oil, whatever—it all comes off with water.
Let them drip dry for a few minutes and put them back in. They look brand new every time. No scrubbing, no special cleaners, just water.
The material has elastic memory too. If you fold or bend it during cleaning, it snaps back to its original shape. No permanent creases.
Safe for People and Pets
These mats are free of latex, lead, and cadmium. If you've got kids climbing in and out, or dogs riding along, you don't have to worry about toxic materials.
They're eco-friendly and scent-free. No off-gassing, no chemical smell. Just a clean, safe interior.
The SuperCab Specifics
These are made for the SuperCab, also called Extended Cab. That's the body style with two full-size doors up front and two smaller rear-hinged doors in back.
They won't fit the SuperCrew Cab, which has four full-size doors and a larger back seat with a different floor shape.
If you've got a 2009-2014 F-150 SuperCab with factory carpet, these are made for your truck.
What You Get
The set includes three pieces. Two for the front row—driver and passenger. One for the second row that covers the back floor area.
The front mats have raised edges to contain spills and debris. Everything you track in stays on the mat, not your carpet.
The rear mat is one continuous piece that protects the whole back area. If you've got passengers, kids, dogs, or just use the back for storage, this keeps everything contained.
The Long-Term Value
These mats will outlast your truck. No cracking, no warping, no fading. The high-density TPE is thicker than standard rubber and built for years of abuse.
And when it comes time to sell, you can pull them out and reveal carpet that still looks new. That matters for resale.
Final Thoughts
The 2009-2014 F-150 is a solid truck that's still on the road in big numbers. Keeping the interior clean is one of the best ways to preserve it.
TPE floor mats are the simplest solution. They fit perfectly, clean instantly, and last forever. No smell, no sliding, no staining. Just protection that works.
If you're tired of fighting mud and salt in your F-150, these mats are worth a look.
*What do you use to protect your F-150's interior? Drop your experience below.*
Why the Fit Matters
What About Cleaning
What You Get
The Long-Term Value
Final Thoughts
