I picked up my 2010 Silverado 2500HD Crew Cab about four years ago, and it's been my daily driver and work truck ever since. These GMT900 trucks are a sweet spot—they've got modern enough features to be comfortable, but they're still simple enough to work on without a computer science degree.
But there's one thing that's bothered me since day one. The carpet.
These trucks have a lot of floor space. The Crew Cab gives you room for passengers or gear, but that also means a lot of carpet to protect. And if you actually use your truck for truck stuff, that carpet takes a beating.
I ended up with a set of Trucktok Silverado Sierra 2007-2013 1500 & 2007-2014 2500HD 3500HD Crew Cab All-Weather TPE Floor Mats that have completely changed how I think about protecting my truck's interior.
The Carpet Problem in These Trucks
The GMT900 interiors are decent. They hold up okay for their age. But the carpet is still carpet. It absorbs everything.
Mud gets ground into the fibers. Snow melts and soaks in. Road salt leaves white stains that never come out. Coffee spills become permanent artwork on your floorboards.
Once that happens, there's no fixing it. You can clean, but you'll never get it back to new. The fibers mat down. The stains set. And replacing carpet in a Crew Cab means pulling seats, removing trim, and spending a whole weekend on a job nobody enjoys.
The solution isn't better cleaning. It's better prevention.
Why TPE Makes Sense
I'd always used rubber mats before. They're cheap, they're everywhere, and they sort of work. But rubber has some real drawbacks.
Rubber mats smell. On a hot summer day, that chemical odor fills the cab. In a truck you spend hours in, that gets old fast.
Rubber gets stiff when it's cold. Try pulling out a frozen rubber mat sometime—it's like handling a sheet of plywood.
Rubber cracks and warps over time. A few years of temperature cycles and they start looking rough.
TPE is different. There's no smell, even when the truck has been sitting in the sun all day. It stays flexible whether it's below freezing or baking hot. It doesn't crack or warp. And it's lighter than rubber while being just as tough.
What Makes These Fit Different
The GMT900 trucks have a unique floor shape. The transmission tunnel on the 2500HD and 3500HD is particularly pronounced. Universal mats just don't work.
These are custom-molded specifically for these trucks. They hug that high-convex tunnel perfectly. No gaps, no bunching, no sliding.
They snap right into the factory retention posts too. Once they're in, they're not going anywhere. No sliding forward under the pedals, no shifting around corners. Just solid, secure coverage.
The Cleaning Factor
Here's the thing that sold me. When these mats get dirty, you pull them out and hose them off. That's it.
Mud rinses away instantly. Salt dissolves and disappears. Coffee, oil, whatever—it all comes off with water.
Let them drip dry for a few minutes and put them back in. They look brand new every time.
No scrubbing. No special cleaners. No hauling them to the car wash. Just water and a few seconds.
The High Tunnel Challenge
The 2500HD and 3500HD trucks have a taller transmission tunnel than the 1500s. It's one of those things you don't think about until you try to find floor mats that actually cover it.
These mats are designed specifically for that high tunnel. They contour perfectly, creating a flat surface that doesn't bulge or gap. Your passengers won't be fighting with a mat that's trying to slide off the tunnel.
What About Heat and Odor
These trucks get hot inside during summer. Dark interiors, lots of glass, and hours in the sun. Cheap mats can make that worse by off-gassing that rubber smell.
TPE doesn't do that. It stays completely odor-free no matter how hot it gets. The interior stays fresh.
The Crew Cab Coverage
You get three pieces total. Two for the front—driver and passenger. One massive piece for the back seat that covers the whole rear floor area.
The front mats have raised edges to contain whatever you track in. Mud, snow, water, salt—it all stays in the mat instead of running onto your carpet.
The rear mat is one continuous piece. If you've got kids, dogs, or just use the back for gear, this keeps everything contained. No dirt sneaking through gaps.
Which Trucks These Fit
These are specifically for Crew Cab trucks. Here's the breakdown:
Final Thoughts
The GMT900 trucks are some of the best Chevy ever made. They're comfortable, capable, and still holding up strong after all these years. Keeping the interior clean is one of the best ways to preserve them.
TPE floor mats are the simplest solution. They fit perfectly, clean instantly, and last forever. No smell, no sliding, no staining. Just protection that works.
If you're tired of fighting mud and salt in your Silverado or Sierra, these mats are worth a look.
Why TPE Makes Sense
The Cleaning Factor
- 2007-2013 Silverado/Sierra 1500 Crew Cab (not the Classic body style)
- 2007-2014 Silverado/Sierra 2500HD and 3500HD Crew Cab
Final Thoughts
