How Well Do TruckTok Floor Mats Protect a 2019-2025 Silverado Crew Cab?
I picked up my 2021 Silverado 2500HD Crew Cab about two years ago, and it's been my daily driver and work truck ever since. These new GMT T1XX trucks are a huge step up from the previous generation. The interior is nicer, the ride is smoother, and the technology actually works. It's a truck you don't mind spending hours in.
But there's one thing that hasn't changed. Carpet still gets destroyed by real-world use.
These new trucks have even more floor space than the old ones. The Crew Cab is massive. That's great for passengers and gear, but it also means a whole lot of carpet to protect. And if you actually use your truck for truck stuff, that carpet takes a beating.
Before finding the right floor mats, I tried several different options. I eventually chose TruckTok's TPE floor mats, and after using them for over a year, I'd like to share my experience.
The Problem with Factory Carpet
The carpet in these new trucks is nice. It's soft, it looks good, and it matches the upscale interior. But it's still carpet. It still absorbs everything.
Mud gets ground into the fibers the first time you get in with dirty boots. Snow melts and soaks in before you even realize it. Road salt leaves white stains that never fully come out. Coffee spills become permanent artwork on your floorboards.
Once that happens, there's no fixing it. You can scrub, you can shampoo, but you'll never get it back to new. The fibers mat down. The stains set. And replacing carpet in a Crew Cab means pulling seats, removing trim, and spending a whole weekend on a job nobody wants to do.
The solution isn't better cleaning. It's better prevention.
Why I Looked at TruckTok
I'd heard about TruckTok from a few guys in online forums. They make a lot of diesel performance parts, but they also have a whole line of floor mats. The prices were reasonable, so I figured I'd give them a shot.
What sold me was the material. They use TPE—thermoplastic elastomer—which is different from the rubber mats I'd used before.
Rubber mats have some real problems. They smell on hot days. They get stiff in cold weather. They crack and warp over time. TPE doesn't do any of that. It's odorless, stays flexible in any temperature, and doesn't degrade.
What Makes TruckTok Different
The first thing I noticed when I opened the box was how substantial these mats feel. They're thick. Not flimsy like some cheap mats I've tried. The high-density TPE is clearly built to last.
The fit is spot on too. These are laser-scanned for the 2019-2025 Crew Cabs. Every contour matches perfectly. The transmission tunnel is hugged tight. The edges come up exactly where they need to. No gaps, no bunching, no sliding.
They snap right into the factory retention posts. Once they're in, they're not going anywhere. No sliding forward under the pedals, no shifting around corners. Just solid, secure coverage.
The Tray-Style Walls
One feature I really appreciate is the raised tray walls. This isn't a flat mat with a tiny lip. It's a deep tray designed to actually contain stuff.
When you get in with snowy boots, the snow melts. With flat mats, that water runs right off onto your carpet. With these high walls, it stays contained until you can clean it out.
Same thing with mud, coffee spills, or whatever else ends up on your floor. Everything stays in the mat. Your carpet stays dry and clean.
The fluid holding capacity is substantial. You'd have to spill an awful lot to overflow these things.
The Cleaning Factor
Here's the thing that sold me. When they get dirty—and they will—you just pull them out and hose them off. That's it.
Mud rinses away instantly. Salt dissolves and disappears. Coffee, oil, whatever—it all comes off with water. Spray them down, let them drip dry for a few minutes, and put them back in. They look brand new every time.
No scrubbing. No special cleaners. No hauling them to the car wash. Just water and a few seconds.
Resistant to the Bad Stuff
These trucks see some harsh conditions. Road salt in winter. Gasoline spills at the pump. Oil from job sites. All of that can destroy cheap mats.
The TruckTok mats are resistant to caustic road salt and gasoline. They won't break down or get damaged by the stuff that ends up on your floorboards. That's a big deal for long-term durability.
No Smell, Even in Summer
If you've ever had cheap rubber mats, you know the smell. On a hot summer day when your truck has been sitting in the sun, that chemical odor fills the whole cab. After a few hours of driving, it gets old fast.
These mats don't have that problem. They're completely odorless, even after hours in direct sun. The interior stays fresh.
The Crew Cab Coverage
You get three pieces total. Two for the front—driver and passenger. One massive piece for the back seat that covers the whole rear floor area.
The front mats have those raised tray walls to contain whatever you track in. Mud, snow, water, salt—it all stays in the mat.
The rear mat is one continuous piece. If you've got kids, dogs, or just use the back for gear, this is essential. Everything that happens back there lands on the mat, not your carpet. No gaps, no dirt sneaking through.
The Under Seat Storage Note
One thing to pay attention to with these newer trucks is the under-seat storage. Some Crew Cabs have carpeted storage bins under the rear seat. Some have plastic storage. These mats are designed for trucks with carpeted storage.
If your truck has the plastic storage bins, these won't fit correctly. Check your configuration before ordering.
Which Trucks These Fit
These are specifically for Crew Cab trucks with carpeted under-seat storage:
  • 2019-2025 Chevy Silverado 1500 Crew Cab
  • 2019-2025 GMC Sierra 1500 Crew Cab (including Denali)
  • 2020-2025 Chevy Silverado 2500HD/3500HD Crew Cab
  • 2020-2025 GMC Sierra 2500HD/3500HD Crew Cab
They won't fit Regular Cab or Extended Cab trucks. The floor shape is completely different. And they're not for the Silverado EV.
The Long-Term Value
Good floor mats aren't cheap, but cheap floor mats aren't good. I learned that lesson the hard way.
These TruckTok mats will outlast your truck. No cracking, no warping, no fading. The high-density TPE is thicker than standard rubber and built for years of abuse.
And when you eventually sell the truck, you can pull these mats out and reveal carpet that still looks new. That's real value at trade-in time.
Final Thoughts
The 2019-2025 Silverados and Sierras are some of the best trucks Chevy and GMC have ever built. They're comfortable, capable, and packed with features. Keeping the interior clean is one of the best ways to preserve them.
The TruckTok TPE floor mats are the best solution I've found. They fit perfectly, clean instantly, and last forever. No smell, no sliding, no staining. Just solid protection that works.
If you're tired of fighting mud and salt in your Crew Cab, these mats are worth a serious look.
What do you use to protect your T1XX interior? Drop your experience below.
